1 - 2 of 2 Posts
Could some body explain to me the differances in the evo4 engine and the american 1g and the 2g engines. Which of the two american engine's more similar to the evo engine and do the crankshafts interchange with each other and if they don't what are the differances.
THANK YOU.
Well, the most major difference is that the EVO4 engine is rotated 180 degrees. where the American versions are same as the EVO 1-3.. and those are identical, but even then they are only similar to the 1g american 4g63's... the 2g's were quite different! The cranks are different, the head is different(but can still be swapped).. if you want to know more about the American versions, just let me know...
1 - 2 of 2 Posts
