Will 350mm 2 piece discs fit on my 4
With standard brembos.I see some places selling discs and calipers up to 365mm diameter for evos 4-9.
Can you just buy a fitting kit of some sort to mount these?
Hope I'm making sense.any help appreciated
Thanks.
350mm discs are from the evo x which will fit your 4 if you buy evo x calipers and drill out the holes in the hub from 12mm to 14mm. This will also require you to run 18" wheels due to the larger discs.
OK cheers for the info,mite just stick with my current setup and buy some direct fit discs as X calipers Plus' wheels would be expensive.is it the width of 18's that cause a problem?I've evo7wheels on at the moment with 225/45/17 and haven't any issue.arches are rolled and on adj collies
