1 - 19 of 19 Posts
Banned
255LPH Intank Kit **Special**
This is our FP 255LPH Intank Kit.
Info - http://www.fuelperformance.co.uk/index.php?route=product/product&path=92_187_221&product_id=1093
LIFE TIME WARRANTY! & are specifically designed to be E85/ETHANOL compatible!
EVO Specific Strainer Fitment Kit!
Our EVO Kit includes our New FUEL PERFORMANCE VITON O-Rings for the Fuel Pump outlet.
O-Rings Tested to 100psi.
No more loosing fuel pressure on the Outlet due to worn OEM Grommets or poor install parts.
£64.99 each Including UK Delivery !
[email protected]
Banned
Discussion Starter · #2 · (Edited)
DESIGN FEATURES:
The FUEL PERFORMANCE HFP 255LPH Intank Fuel Pump has a number of design advantages compared to a Walbro 255 pump, or generic offshore unproven "255LPH" pumps sold by fulfillment warehouses instead of real performance shops.
1. Except for a faint "wheen" during pump priming, FP pumps are nearly silent. Walbro pumps are notorious for their loud vibrating "hum" during operation.
2. FUEL PERFORMANCE 255LPH pumps can also be used as direct replacement pumps, without overpowering the factory fuel pressure regulator. This is not the case with Aeromotive Stealth 340LPH and Walbro 400LPH intank fuel pumps. The advantage of modern return-style fuel systems is that they only use as much fuel as the engine requires. Any unused fuel is automatically sent back to the tank via the return line. Using a 255LPH pump instead of an OEM replacement will simply provide room to grow if any modifications are planned for the future.
3. FUEL PERFORMANCE pumps are manufactured to our specifications to balance volume, pressure, and turbine impeller angle to prevent overheating of the fuel.
4. FUEL PERFORMNACE backs every single pump with a Lifetime Warranty. Walbro requires that you pay a $40 "warranty fee" when you send the pump in which often results in them telling you it was installer error, not pump failure.
5. FUEL PERFORMANCE pumps are flow verified by RC Engineering and are guaranteed to flow higher than any 255LPH/ 265LPH/ 300LPH pump on the market (flowsheets on our website).
Banned
Couple of these shipped out this week via our website for EVO's.
Same Day Shipping!
Lifetime Warranty!
EVO Specific Install/Strainer Kit!
1 - 19 of 19 Posts
