1 - 3 of 3 Posts
· Registered
2015 Mitsubishi Lancer Evo Final Edition
For some information. This car is not daily driven since the pandemic, kept in the garage.
Once you get in the car the lights everything turns on, go to turn the car on it activates the dash and stereo. Go to turn the car on it starts to cranks but will NOT turn over. It does have an older tank of gas in it. Car has less than 27k miles on it. The car will let you continuely try to start it, continuely cranking over and over just not firing.
The car has some mods but was done back in 2018, with no issues since then. Biggest thing is that the car fired up back in the summer, drove fine. I'm kicking myself in the butt thinking it might be the gas which could make the sparks go bad?
Battery - New
Relays - Ones from MAP - Just tried this trick so are New
Fuel Pump - you can hear it pumping
No new engine codes but a P0420 - it's because of the aftermarket exhaust and downpipe, never been an issue before, been done since 2018.
Tried with the key fob and the key.
Should I try changing the sparks?
Haven't tried doing the roll and start as I wouldn't be able to get it back into the garage (slight hill going into the garage.)
Any ideas would be greatly appreicated.
Thanks!!!
· Registered
Found the issue, feeling dumb, but so fking happy. The person who installed the aftermarket headlights mounted the fuses in the wrong place and was trying to bypass the ignition fuse. It was never an issue until maybe when I was changing the relays I bumped the headlight fuse and I thought I put it back into the correct location..... It was stopping the car from fully turning over. Now that fuse area has been seperated and won't ever be an issue.
1 - 3 of 3 Posts
