1 - 20 of 21 Posts
Profound thinker
*** OFF THE MARKET *** *** TAKEN OFF THE MARKET *** *** OFF THE MARKET ***
Offered for sale only on the MLR and with some tangible regret because it is such a fantastic driver's car...
2005 Evolution IX FQ-320
Electric Blue
107,000 miles
Owned from new, first registered 6 Sep 2005 - 55 plate. Full service history and meticulously maintained (see later for service and maintenance schedule). Last service recently on 2 May 17
A massive dossier of all service, maintenance and repair work and parts bought is included with car.
MOT expires Nov 2017
Exterior:
Paintwork in good condition
MR360 carbon front splitter, painted body colour
18" Ultralite A-tech wheels custom painted in dark grey metallic centre graded out to silver rims
Good Year Eagle F1 Assymetric 2 - loads of tread remaining
Ralliart mud-flaps newly fitted
PIAA aero silicone wipers newly fitted (wiper arm recently replaced and painted satin black)
Bad points:
Small dent in rear passenger side door - dent repair would easily sort this
Slight surface rust beginning to appear on lower leading edge of rear arches - this is only surface rust and can easily be fully repaired
Car has seen some bodywork/paint over the years mainly from stone-chips and unavoidable scratches from public car parks.
Engine:
Rod Job and forged drop-in pistons carried out by NR Autosport in May/June 2015 on 91,000 mile engine. Engine was reported as in very good internal condition with no damage or wear to cylinder bores. Full cylinder-head strip and refresh/rebuild. Valves re-ground and valve seats re-cut. Head skimmed. Injectors cleaned and flow-tested, new cam-belt etc. (See Service Invoice Jun 15)
Bad points:
Slight oil seep from sump seal, maximum 1 or 2 drips tell-tale per week. Engine uses no oil, though and never needs any top-up. Sump just needs removed and re-seated/re-sealed.
Parts Used for engine refresh:
85mm JE pistons
Manley H-beam rods
ARP head studs
ACL rod bearings
Walbro fuel pump 255ltr/hr
Cambelt
1.3mm head gasket
NR baffled oil sump with black powder-coat
Supporting modifications:
Link G4+ plug and play ECU mapped by NR. Coil-on-Plug ignition system running full sequential ignition on Link G4+ with MAF removed and mapped on boost sensor
Original turbo running 1.8 bar boost
MAC 3-port boost solenoid
3mm lash adjusters (will be replaced in the next few weeks due to intermittent very slight tappet noise)
Mishimoto alloy radiator with slim-line fans installed
Mishimoto Race alloy intercooler
K&N cone filter on custom hard pipes
3" Scorpion downpipe, 3" silenced JapSpeed de-cat and full stainless 3" HKS Hi-Power Silent Exhaust - track friendly 90dB
Oil catch can installed
Alternator changed June 2015; Air-con compressor changed and system re-gassed June 2015
Chassis/drivetrain:
Meister-R GT1 adjustable suspension setup with pillow ball top mounts - running custom geometry settings
GT1 suspension will be serviced, stripped and rebuilt over the next couple of weeks prior to sale
SuperPro front roll-centre adjustment kit installed
BLOX roll-stopper lower engine mount - second gear known to be stiff on 6-speed gearbox when cold - this helps
Helix Organic clutch kit
Cusco style alloy strut braces front and rear: 3-point front and 2/3-point rear normally running 2-point but with boot attachment point installed to run 3-point for track-days
All worn suspension bushes have been recently replaced at Mitsubishi with OEM items (Apr 17)
Braking:
Standard Brembo calipers
M-Tech grooved and dimpled discs all-round
Project mu HC800 front pads; Ferodo DS2500 rear pads
Braided brake lines all round. Corroded brake pipes (reported in MOT) replaced with full braided lines.
Interior:
Standard FQ-320 interior in good condition
New MLR/Ralliart floor mats
Mechanical boost gauge and Innovate Air-Fuel-Ratio gauge installed on steering column
(AFR sensor installed into decat pipe)
Sony blue-tooth stereo with iPod and Aux inputs, microphone installed for hands-free calling
Momo metal pedal covers on brake and clutch pedals and Ralliart drilled metal cover on footrest
Bad points on interior:
Scratching on leather centre section of rear bench seat.
Minor scuffs on plastic rear shells of front seats. Nothing major.
Recall work carried out:
Light-stalk circuit board recall and passenger air-bag recall work completed in 2017
No outstanding recalls
Major repairs carried out:
Gearbox stripped and rebuilt twice during 2010/11 at circa 50,000 miles. First time was for 4th gear stripped teeth - a relatively common issue. Second time was for inability to select 3rd gear - we found the internal geared selector ring had cracked and expanded so that it wouldn't fit into the geared outer selector ring. Components replaced with new and input/output shafts were micrometer measured and properly shimmed by NR Autosport. No issues since then and gearbox feels very positive to use. Sometimes a little notchy going into 2nd when cold, but this is a known 6-speed 'box feature. Fitting the BLOX roll-stopper lower engine mount helps with this, but doesn't truly eliminate the notchiness.
AYC pump has been rebuilt.
IMPORTANT - Work that will be required on car:
This is the important bit and this is the reason that I am advertising the car on the MLR only and the reason for the low asking price. Recent inspection at AutoTorque has highlighted that the rear portion of the chassis rails are beginning to rust. They're not rotten yet, as such, and car is safe to drive, etc, but the rear rails will begin to rot out if not replaced or repaired soon. I have booked the car in at AutoTorque on 2 Oct 2017 - this is the very earliest that they are willing to take on this work, otherwise I would have it done now and prior to advertising the car. The work will take 1 week to complete. Quote for replacing chassis rails and completing a full under-body restoration, cavity wax and under-seal was around £4,500, with options to replace a number of bushes and other ancillaries at extra cost (which aren't worn, but while the sub-frames are out it is a good idea to do this at little-to-no extra labour charge). This would fully restore the under-body and give a car that would be a year-round care-free daily driver for a good number of years (AutoTorque supply a 5 year warranty on under-body restorations - but the work would definitely out-last this warranty by another 2-to-5 years. As a comparison, this car lasted over 10 years with the Mitsubishi under-seal before rust became an issue).
The car is still fine as it is at the moment, but the work will be required before the chassis rails begin to rot from the inside out. Now I know that these cars do rust and can rot badly, I would recommend that all Evo road cars get a restoration completed on the underside anyway as a preventative measure. I just wish I'd known this before and I would've had it done a couple of years ago as prevention.
With that fully disclosed the asking price will be firm £10,500.
So for a total outlay of around £15,000 if you went the whole AutoTorque restoration route, the car would be completely sorted and probably value at over this figure.
Contact details:
Mobile -
PM on MLR
email:
Yours Aye
Mark H
Profound thinker
Discussion Starter · #2 · (Edited)
Pictures added Sun21 May.
First one was taken a couple of weeks ago before I made the Intercooler bracket stealthy.
This is how I made the visible part of the bracket "disappear" with satin black paint...
Garaged every night
Engine bay - the Tein top mounts are for the temporary suspension while the GT1s are getting re-build.
Also, see [my car] for a history of the car, mods list, and pictures
Profound thinker
Discussion Starter · #3 · (Edited)
Comprehensive Service and Maintenance history - with documentary evidence.
Service 1 - Lincoln Mitsubishi - 6 Mar 06 - 4,487 miles
Service 2 - Lincoln Mitsubishi - 29 Aug 06 - 8,087 miles
Tyre fitting - 19 Oct 06 - 9,476 miles
Service 3 - Lincoln Mitsubishi - 16 Mar 07 - 12,796 miles
Service 4 - Lincoln Mitsubishi - 11 Sep 07 - 17,915 miles (Note the human error - no mileage on invoice. However, mileage is recorded in service booklet above)
** Unable to get a full garage service completed due to work, so an oil change was performed on 27 Mar 08 at 22,879 miles. **
Service 5 - NR Autosport - 11 Apr 08 - 24,847 miles
Service 6 - NR Autosport - 20 Aug 08 - 27,845 miles
Service 7 - NR Autosport - 17 Dec 08 - 31,711 miles (note the human error in the mileage on invoice! Correct miles on service booklet.)
Brake system maintenance - 6 May 09 - 35,426 miles
Service 8 - NR Autosport - 6 Jul 09 - 37,045 miles
2009 MOT - 20 Aug 09 - 37,738 miles
Service 9 - NR Autosport - 8 Jan 10 - 41,434 miles
Service 10 - Cambelt - NR Autosport - 10 May 10 - 45,671 miles
3mm Lash Adjusters fitted - NR Autosport - 7 Jun 10 - 47,748 miles
Off-schedule AYC Service - NR Autosport - 3 Sep 10 - 49,916 miles
Service 11 - NR Autosport - 22 Sep 10 - 50,164 miles
Gearbox repair and clutch fitting, etc - 22 Oct 10 - 50,950
Suspension coil-over roller-pin bearings fitted - 26 Nov 10 - 52,361 miles
More suspension work and electrical fix - 12 Dec 10 - 53,196 miles
Service 12 - NR Autosport - 18 Jan 11 - 54,316 miles
Gearbox repair and AYC pump refurbish - 28 Apr 11 - 56,342 miles
Service 13 - NR Autosport - 30 Jun 11 - 58,726 miles
Service 14 - NR Autosport - 28 Oct 11 - 63,305 miles
Helix Organic Clutch fitted, AYC service - 2 Mar 12 - 66,633 miles
AVO Coil-overs fitted - NR Autosport - 3 Apr 12 - 67,439 miles
Service 15 - NR Autosport - 17 May 12 - 68,703 miles
Service 16 - NR Autosport - 25 Oct 12 - 72,566 miles
Service 17 - NR Autosport - 9 May 13 - 77,466 miles
** I was working out of the country for 5 months, hence a time gap with the car being unused **
Service 18 - NR Autosport - 9 May 14 - 82,811 miles
Service 19 - NR Autosport - 20 Oct 14 - 87,616 miles
Service 20 +++
Drop-in forged pistons, forged rods and full head refresh, baffled sump, etc - NR Autosport - 29 Jun 15 - 91,291 miles
Alloy Radiator fitted - NR Autosport - 4 Apr 16 - 94,468 miles
Service 21 - NR Autosport - 22 Apr 16 - 94,649 miles
Service 22 - MG Autos - 22 Nov 16 - 100,734 miles
All worn suspension bushes replaced - Lincoln Mitsubishi (NR) - 18 Apr 17 - 105,864 miles (Human error on invoice!)
Service 23 - Mitsubishi Lincoln (NR) - 2 May 17 - 106,147 miles (human error on invoice again! Service booklet displays correct mileage.)
WOW - that was time-consuming
Mark H
Profound thinker
2 calls already
1 Viewer already en-route
Wow
Good luck mark hope you get an honest buyer as you have been with your ad, keep us posted on what happens and hopefully what you are getting :D :smthumbup All the best Rob ;)
Profound thinker
Discussion Starter · #7 · (Edited)
Initial agreed sale fell through.
See new post below...
Yours Aye
Mark H
Regional Organiser
Not surprised this sold so quickly....a totally honest advert with a really reasonable price :smthumbup:smthumbup
Pleased for you :smthumbup
Profound thinker
Discussion Starter · #10 · (Edited)
A "fair" price.
Buyer probably happier than the seller, but still a fair price.
Flash-to-bang less then 3.5 hrs with buyer having a 2hr journey to view. Gotta be some kind of record.
Ah well. An enforced break from Evos for me for a while. Don't see it being permanent, though.
End of an era :cry:
Well done on the quick sale Mark and good luck with the new toy, looking forward to seeing your wanted ad next year. :lol:
All the best.
Profound thinker
Discussion Starter · #12 · (Edited)
Meister-R GT1 suspension currently being rebuilt for new buyer as promised.
These coil-overs are really standing up well to daily year-round driving. No corrosion issues at all on the threaded bodies or anywhere else.
:D
Mark H
Profound thinker
Well done on the sale, you going for the Alfa now?
Big change of plans.
We are changing the Mrs car now as well, and putting some money into a loft conversion.
My plan is to run a ~£3k Honda CTR from around 2004 for a while. Maybe even take it to the North Loop in July...
Yours Aye
Mark H
Profound thinker
Discussion Starter · #16 ·
Are you in Woodhall mate? Pop over and have a spin in mine in you miss it too much!
Glad the sale went well for you.
Thanks for the offer of a spin, I'll keep it in mind matey, I'm not far from you, near Metheringham. :smthumbup
Cheerz
Mark H
Profound thinker
Discussion Starter · #17 ·
*** BACK UP FOR SALE ***
** IMPORTANT **
SOMETHING ELSE HAS JUST COME TO LIGHT THAT I WASN'T AWARE OF UNTIL THIS WEEK...
There is a mistake on the recorded mileage of first MOT in 2009.
I am in contact with DVSA to try to sort this out.
Any interested buyer please note that the MOT recorded on 20 Aug 09 was on the same date as an invoice for a service photo shown above. MOT mileage recorded as 49,000. Actual mileage on that day, as recorded in the invoice above is 27,845.
Sadly, I didn't notice the error on the MOT certificate at the time.
Yours Aye
Mark H
Reactions: M3 ROB
Profound thinker
Discussion Starter · #18 ·
Adding pictures of the car - including details of the "bad bits" mentioned in the post #1 text.
Yours Aye
Mark H
Profound thinker
Discussion Starter · #19 ·
Our loft conversion project could be brought forward into June (with a little discount from builder) so today I am reducing the asking price to £10,500 to get our builder started.
2 more things to include:
2 original keys, 2 alarm fobs and 2 alarm touch-sticks included.
Catalytic convertor also included (for MOTs)
Yours Aye
Mark H
Profound thinker
Discussion Starter · #20 ·
Taken off the market.
Green light has been given for our loft conversion project :smthumbup
Cheerz
Mark H
1 - 20 of 21 Posts
