I normally keep the iddle higher than normal so you havnt that far to reach turbo cut in .
As ready to launch blip throttle to get turbo spinning ,then let out clutch on second big blip of throttle ,change very quick to second if your lucky you'll do it before the revs drop,third will come quickly as well ,and just as easy to hit the red line,change to third floor the throttle and just watch the rev counter and not the speedo.Go past the line in 4th not 5th as you'll be slower on the last gear change.
3rd is an easy gear to miss .get it right and 13s terminal around 110 mph should be achieved .I would bank on around 13.3s for a standard E6 1/4 mile .
E2/4/5 I have seen in early 13s.
Bloody great fun,should get 6-8 good launches on a standard clutch before its knacked ,unless youv'e done a fair mileage already and some quick rd starts.
Couple of pointers .
carry an Ice bag with crushed Ice to put into the washer bottle for the water spray,and use it .chuck out all bits not required for driving ,tuck your wing mirrors in and don't put in much fuel.Slicks on a hot day advisable.
I did non of the above and hit a 13.5s in my E4.http://194.93.140.171/graphics/happy1.gif border|EQU| 0 align|EQU| absmiddle >
Happy straight lining.
Don't roll at beginning as this will set your time off and your fked with a 14.5 sec .
Its all revs from the start ,
