#1 |
User
![]() Join Date: Nov 2020
HKS Silent Hi-Power Modification
Greetings!
We recently purchased a non-running Evo 5 project. We had hoped to use the existing exhaust (Fujitsubo), but corrosion has taken its toll. ![]() We prefer a standard exhaust (non-angled) and quiet due to neighbors/laws. The HKS Silent Hi Power is our top choice currently, but understand it is not a full 3 inch tip to tip. There is a neck down at some point - possibly at the resonator? We are adding a 3 inch elbow/down pipe and would like to maintain to the rear. We've read where folks modify this section for full 3 inch - ask if folks could offer an image or instructions on how to accomplish. Thanks! |
Sponsored Links | |||
Advertisement |
#3 |
User
thetyrant: Thanks for the response. Goal is only 400, but hate to be inefficient at 'upgrades.' We aren't even positive where the issue is.
Advertisement |
#4 | |
If you want 3" then i would go the magnex 3" from rossport with rolled in tailpipe version if there is still 2 options, the rolled in tip is much quieter than massive slash cut version and makes sensible amount of noise, might need to add another silencer if you want it really quiet as true 3" and oem type quiet is tricky! |
#5 |
![]() Join Date: Jan 2006
Russ fellows should be able to make what you want
Need evo |
Advertisement |
Thread Tools | |
