Evo 3 - Mitsubishi Lancer Register Forum
Go Back   Mitsubishi Lancer Register Forum > General Stuff > Lancer Chat
Old 13-01-2021, 14:58   #1
D.D.A
Evo 3
Looking at a evo 3
Problems to look for please
Are parts still available
Engine reliability
Anything that may help
Ant 1s old car I believe
Need evo
D.D.A is offline   Reply With Quote
Old 13-01-2021, 15:25   #2
thetyrant
Car: BMW 130i & MR2 Roadster - Previously: Evo9, Evo5, 2 x Evo2, all gone but not forgotten.
Engine is strong and lot of parts from later cars like pistons etc can be fitted if needed, but the E1/2/3&4 can suffer crankwalk issues as the thrust bearing design is poor compared to later cars, when this wear the crank endlfoat goes out of spec and can destroy engine, although if caught early it can sometimes be sorted with just a bearing swap but all depends how far gone it is and condition of everything, some cars go many miles without issue as well.
Other potential issue is Gearbox as they have a weak 4th gear especially if tuned and can spit off a tooth which usually shoots out the bottom of box casing!, i did 3 of these when i had my Evo2 , casing can usually be repaired but problem is getting the new gears if they do break as im pretty sure discontinued now and while you used to be able to get in japan i would be surprised if any left now, there was a guy in europe doing a stronger straight cut 4th gear setup but not sure if still available.
Other than that great cars when everything is good and i prefer to drive to laters Evos, ive had a E5 and E9 as well as 2 x E2 in past and the early cars served me well over the years and many many miles, i would have another if gearbox parts were available easily, last gbox i had was full rebuild many new parts and lasted 40k+ miles before spitting 4th off again, that car was a 2.3 stroker motor with 400lbs of torque and driven hard though.
thetyrant is offline   Reply With Quote
The Following 2 Users Say Thank You to thetyrant For This Useful Post:
D.D.A (13-01-2021), Pushpex (13-01-2021)
Old 13-01-2021, 15:45   #3
Mita
I always fancied doing a later engine swap on an early. Solves a lot of the above issues but is a big old project
Old 13-01-2021, 15:47   #4
ant1
ant1's Avatar
Car: Evo TME RS
Not seen that car in years.
I would be checking for rust, the underside used to be mint. Like new in fact but I used it with no underseal as it was dry use only. Not sure what has been applied since.
ant1 is offline   Reply With Quote
The Following User Says Thank You to ant1 For This Useful Post:
D.D.A (13-01-2021)
Old 13-01-2021, 15:56   #5
grants
grants's Avatar
Good thread here
https://www.lancerregister.com/showthread.php?t=580743
Old 13-01-2021, 16:17   #6
thetyrant
Yes same here if i could get a car cheap enough i would do it but price of the cars is silly now so makes it a hard pill to swallow, the later E5-9 engine/box swap isnt that involved if you have all right bits but there is some fab do to of course with engine and box being 180degree rotated, from memory looking at that one NR did notching the subframe to make space for transmission being main part of it.
The Following User Says Thank You to thetyrant For This Useful Post:
Mita (13-01-2021)
Old 13-01-2021, 16:21   #7
Mita
You’re not wrong, proves now make it a bit of a dead end
Would be awesome to do
Old 13-01-2021, 18:58   #8
RSgeoff
Car: M135i X Drive
Do you not look at your Avatar?
RSgeoff is offline   Reply With Quote
Old 13-01-2021, 19:17   #9
ant1
ant1's Avatar
Car: Evo TME RS
Good one
Old 13-01-2021, 19:42   #10
Pushpex
Don't talk about doing another project, you'll scare Dave-Cee
Pushpex is online now   Reply With Quote
The Following User Says Thank You to Pushpex For This Useful Post:
Mita (14-01-2021)
Old 14-01-2021, 09:41   #11
Mita
