getting an MOT without a cat - Mitsubishi Lancer Register Forum
Go Back   Mitsubishi Lancer Register Forum > General Stuff > Lancer Chat
Old 19-11-2020, 13:37   #1
jackg
User
My EVO doesnít have a Cat and has failed itís MOT on emissions. Is there a way around this?
Ta
Jx
jackg is offline   Reply With Quote
Old 19-11-2020, 13:48   #2
Humps85
Put a cat on it. Or dodgy mot.
Humps85 is offline   Reply With Quote
Old 19-11-2020, 13:50   #3
jackg
User
Mine is a 6 . I had a Cat off an 8 which is longer but we bodged it on and it still failed!
PM if anyone knows a dodgy one!
Jx
Old 19-11-2020, 17:45   #4
evo/nut
MLR Registered User
evo/nut's Avatar
Car: EVO VII FQ300 - SOLD * EVO VIII MR FQ340 - SOLD * EVO IV - SOLD * EVO IV - SOLD * EVO VIII MR FQ340
Jx
PM'd
SHOWS 2021
Hopefully some will go ahead.......
evo/nut is offline   Reply With Quote
Old 19-11-2020, 19:58   #5
Mita
Dodgy git
Originally Posted by evo/nut View Post
PM'd
squeakyclean32 (20-11-2020)
Old 19-11-2020, 20:00   #6
evo/nut
MLR Registered User
evo/nut's Avatar
Originally Posted by Mita View Post
Dodgy git
Never
Was trying to find out how much his VI TME RS going to be - and narda, not even the smallest of carrots was dangled
SHOWS 2021
The Following 2 Users Say Thank You to evo/nut For This Useful Post:
Mita (19-11-2020), squeakyclean32 (20-11-2020)
Old 19-11-2020, 20:24   #7
Mita
Millions donít you know.
Never
Old 19-11-2020, 21:22   #8
r3k1355
Very much doubt you'll find an MOT guy willing to risk their livelihood and business for a total stranger.
Perhaps it'd be better trying to find out why it's running rich.
Old 19-11-2020, 22:15   #9
Arronevo8
Get your mapping checked as my vi has never had a cat and never failed a MOT,
Old 20-11-2020, 01:42   #10
evo baz
MLR Oldie
evo baz's Avatar
Leave £50 next to the gear stick ;-)
evo baz is offline   Reply With Quote
The Following User Says Thank You to evo baz For This Useful Post:
Tom Dick (20-11-2020)
Old 20-11-2020, 05:13   #11
4g638
Unless the law is indicative and states that one needs a catalytic converter present so as for the car to be able to take the MOT test, then there is no actual need for a catalytic converter to pass the emission test. HC, CO , CO2, can be mapped out to conform to the appropriate requested values the emission test dictates, once these are mapped out NOX will sort itself out. If you are on factory mapping, you'll not pass the test without a euro3 200cel cat, or a stock cat.
If you are on stock ecu/mapping, you really need to put the stock cat on it, as the ecu is mapped for emissions on that specific stock cat. The evo 8 cat, should get you through though, the two cats differ not only in external dimensions but in internal characteristics, as far as the combination of precious metals used, and that creates an incompatibility between the stock mapping and the cat, but if I remember correctly it is not at such degree that will not allow you to pass emissions. You also need to make sure that the oem O2 sensor is in proper working order and it reads properly.
Marios
" Go tell the Spartans,passerby,that here by Spartan law we lie. " Leonidas I son of Anaxandritas II and king of Sparta,really proud to be his descendant!
4g638 is offline   Reply With Quote
Old 20-11-2020, 06:38   #12
tooshy 320
Your after top money for the car looks very nice and you have bodged a cat on do it properly if potential buyers see this they will be thinking is any think else bodged to get the car away
tooshy 320 is offline   Reply With Quote
The Following User Says Thank You to tooshy 320 For This Useful Post:
gordonm (20-11-2020)
Old 20-11-2020, 07:51   #13
stu8
stu8's Avatar
Car: Evo V - geekmapped.com
Ta
Jx
Jx
Did you get the cat really hot just before testing the emissions, this often needs to be done to get evo's to pass
Stu
CPP Motor Developments -
RG Motorsport -
Old 20-11-2020, 09:16   #14
fozz57
Car: Ralliart Sportback
Marios
Does this mapping adjustment apply to other Lancer models ? Can the Ralliart Sportback be tweaked in this way as I run the car decatted but put the cat back on for the mot.
Brian.
fozz57 is offline   Reply With Quote
Old 20-11-2020, 10:04   #15
Goginawa
Zero Fighter
Goginawa's Avatar
Car: EVO IX FQ 320
Never
Thereís one at SVA imports for 26k minus TME seats
MAPPED BY ORACLE
evoless ,now something on a different Note
Goginawa is offline   Reply With Quote
