Ticking/rattling- clutch implicated, I'm perplexed - Mitsubishi Lancer Register Forum
Old 01-08-2020, 04:26   #1
zestyfesty
Hi Guys, hoping those with some expertise can share thoughts -
Engine has 900km on it since a full rebuild, including new clutch kit. We changed to E85 and upgraded (stock frame) turbo. These items aside, it has been a replacement of existing parts (new forged rods/pistons, bolts, bearings etc).
Chassis has 150,000km, standard 5spd gearbox which has never been opened.
Previous rebuild with same mechanic we got 47,000km of road and 3000km of competition use. I treat my car with mechanical sympathy and never abuse it.
These 900km have only been used on metro roads, light use. Since rebuild there has been an 'idle dip' occurring between gearshifts which mechanic was aware of. This appears to have exacerbated over the past couple of months; standing still, disengagement of the clutch (pressing pedal) drops engine idle and can stall occasionally when engine warm. On the move, engine speed drops rapidly between shifts and will stall if shift is slow.
I've wracked my beginner's level mechanical brain over this for a week.
There is a clear rattling/ticking noise with engine running, that wasn't there after engine was first completed. I thought perhaps this was a clutch bearing (pilot or release? causing noise and maybe poor alignment placing load on input shaft) or maybe an input shaft bearing problem. But the ticking increases in frequency with engine speed, suggesting non-transmission, however as explained the transmission is implicated through depressing clutch.
Noise appears to be concentrated at the front of the engine, not bell housing area (although this is not conclusive)
A light press of the clutch will illicit a change in the nature of the noise, and full clutch depression will drop revs 2-300rpm when sitting in neutral idling.
Any thoughts much appreciated (that car is booked in for inspection in 2 weeks)
I'm reluctant to drive it as it doesn't feel right/healthy, and I'm really perplexed.
Clive? Anyone?
I've tried to add youtube links below, bit of a dork with tech, so hope it works.
[https://youtu.be/-vIhbJs-x2I]
[https://youtu.be/0srtMa6RqWg]
Jim
Cars: Evo VI GSR, Subaru BRZ PP, Toyota Landcruiser 80 Series
zestyfesty is offline   Reply With Quote
Old 01-08-2020, 05:02   #2
zestyfesty
Old 01-08-2020, 07:06   #3
Coggy
Coggy's Avatar
Car: A4
My IV was doing this when I had crankwalk. Revs dropping when the clutch pedal pressed down. I could hear a ticking on mine, which turned out to be the crank reluctor disc eating away at the crank sensor.
Just a thought
oh if i could only get some sleep,
creaky noises make my skin creep,
i need to get some sleep,
i can't get no sleep.......
Coggy is offline   Reply With Quote
The Following User Says Thank You to Coggy For This Useful Post:
plip1953 (03-08-2020)
Old 02-08-2020, 06:55   #4
Hedgehog Dodger
Car: Evo 5 - Forged and mapped by CPP
Send a message via AIM to Hedgehog Dodger
I would check the exhaust turbine housing where the actuator arm is.
I have a rattle on tickover, over run basically when the car is off boost. The flap overtime distorts in the turbine housing and rattles. Common issue on 4 5 and 6 Evos. The 7 onwards had a cap over the top to stop this.
See if the noise is there when the car is under load.
Possible new turbo time
Bought it, blew it, built it.
Hedgehog Dodger is offline   Reply With Quote
Old 02-08-2020, 09:00   #5
zestyfesty
Just a thought
Thanks for your thought. I dearly hope note. It's a newly built engine.
Old 02-08-2020, 09:02   #6
zestyfesty
We fitted a brand new turbo and actuator with engine rebuild 900kms ago, so this is unlikely, but thanks.
Old 02-08-2020, 21:32   #7
Phil2333
Tarmac Tyre Shredder
Phil2333's Avatar
Car: Evo 6, Forged 2ltr 8MR engine...405/400
Exhaust manifold gasket leak....causes ticking noises.
My Evo 6 resto thread...
Phil2333 is offline   Reply With Quote
The Following User Says Thank You to Phil2333 For This Useful Post:
zestyfesty (03-08-2020)
Old 03-08-2020, 06:54   #8
plip1953
Phil
plip1953's Avatar
Car: Evo X RS
My immediate thought was a crankshaft thrust bearing issue.......
Phil
The Following 2 Users Say Thank You to plip1953 For This Useful Post:
Coggy (03-08-2020), zestyfesty (03-08-2020)
