Another Evo 4 Restoration Thread - Mitsubishi Lancer Register Forum
Old 23-05-2020, 20:07   #1
Pushpex
I bought the car last August for a fairly reasonable price, knowing full well it needed some TLC. The inside smells herbal and there's some spot rust around along the body with some questionable repairs to the rear chassis rails, an intercooler which hardly fits and a stupid subwoofer in the boot wired in in the most chavtastic fashion however it drives OK (although needed a wheel alignment) there's no ayc light and the engine is from an evo 5 (with an evo 9 turbo)
I had a lot of fun driving it, but after being told the wheels couldn't be aligned because the tie rod end boots were perished (spoiler- they weren't) I put it on jackstands and in typical fashion the originally small job just grew.
Taking the wheels off I decided the knuckles could do with a good powdercoating
And whilst I was at it I might as well do the subframe and control arms, however it seems the subframe was mounted with some of the most spectacular welding
Having cut the weld off it seems the reason for the welding was because the bolt had been cross threaded causing the captive nut to destroy the cage, allowing it to spin freely.The only way was to take the head off with an angle grinder to get the subframe out
Whilst I was at it I got some nice evo 5/6 alloy control arms though they needed cleaning up
The tired looking N/S bar
Fujitsubo exhaust (the first mod I did to replace the drainpipe exhaust tip that had been installed) and prop shaft
More to come...
Pushpex is offline   Reply With Quote
The Following 3 Users Say Thank You to Pushpex For This Useful Post:
Alex T (24-05-2020), Christopher (20-06-2020), evo5d (23-05-2020)
Old 23-05-2020, 20:23   #2
7722adam
7722adam's Avatar
Car: Evo VI GSR, Evo 8 260
Pics not working for me
Boys never grow up, they just get older and their toys get more expensive, but don't tell the wife that!!
7722adam is offline   Reply With Quote
Old 23-05-2020, 20:24   #3
7722adam
7722adam's Avatar
Ps going through same as doing full underside resto on my 6!! Back to bare metal etc
Old 23-05-2020, 20:35   #4
Mita
Looking forward to updates
Old 23-05-2020, 20:58   #5
leeslancer8
leeslancer8's Avatar
Car: EVO 8 260 - EVO 7 RSII - EVO 8 FQ320 MR - EVO 4 GSR
Yeah shame about the pictures
leeslancer8 is online now   Reply With Quote
Old 23-05-2020, 21:46   #6
Pushpex
Sorry about the pics, tried to link from onedrive but it doesn't seem to be working. Made an imgur account so stay tuned
The Following User Says Thank You to Pushpex For This Useful Post:
leeslancer8 (23-05-2020)
Old 23-05-2020, 21:54   #7
leeslancer8
Have that cat back on mine it’s a nice system
Old 23-05-2020, 22:43   #8
Pushpex
Originally Posted by leeslancer8 View Post
Have that cat back on mine itís a nice system
It's great, JASMA rated so doesn't get annoying on long drives but still excellent when you open the throttle
Old 23-05-2020, 22:56   #9
Pushpex
Had to cut the captive nut out
Made a new one on the lathe at work
Welding it back in
A bit of a challenge welding upside down
Primed
The Following 7 Users Say Thank You to Pushpex For This Useful Post:
dreMR (24-05-2020), evo5d (25-05-2020), leeslancer8 (23-05-2020), LEGNUMVR4 (24-05-2020), McGoo60 (20-06-2020), notenoughtime (06-01-2021), wizzzbang (02-08-2020)
Old 23-05-2020, 23:14   #10
Pushpex
Front subframe and control arms back from powdercoating fitted with superpro bushes
Pordercoated front ARB painted over in blue, unfortunately I didn't prep the powdercoat well so the blue just chipped
Fitted with brembos and HEL brake lines
N/S bar back from powdercoating
Unfrotunately there was a crack in the rear upper control arm
Had a go at welding it but it cracked as soon as I put the bush in
So I got someone who can actually weld amelinium to do it
The Following 2 Users Say Thank You to Pushpex For This Useful Post:
Alex T (24-05-2020), dreMR (24-05-2020)
Old 24-05-2020, 09:56   #11
Pushpex
Any pics? it's a massive pain without a spit but knowing it's safe from corrosion for a few more years is worth it!
Old 24-05-2020, 10:11   #12
Pushpex
Getting the intercooler mounted properly
Note the old bracketry holding the mishimoto intercooler in place
Of course the pipework doesn't fit properly and the thin gauge strips of steel holding the intercooler in place bent down into the brake ducts which caused the arch liners to shred
Made some new brackets out of stainless
(not going to show my amelinium welding )
Some 90 degree hoses to avoid the foglights and brake ducts
Not sure how the sharp angle will affect the boost
Old 01-06-2020, 20:41   #13
Pushpex
Wire wheeling down the old paint
Painted with rust.co.uk 121 Epoxy
Haven't perfected my seam sealing yet
lautll421 (03-06-2020), scottr89 (01-07-2020)
Old 01-06-2020, 20:44   #14
Pushpex
Mounted my new arch liners and then moulded a support in expanding foam
And then moulded them in fiberglass
however they were too rigid to be mounted. Has anyone done anything special to reenforce their arch liners?
Old 20-06-2020, 11:43   #15
EvoIVCed
I’d def like to know as I jus had to replace my driver side arch, after it being crappy for a while.
EvoIVCed is offline   Reply With Quote
The Following User Says Thank You to EvoIVCed For This Useful Post:
richie9 (03-08-2020)
