Evo 4 clutch/flywheel question. - Mitsubishi Lancer Register Forum
Old 22-05-2020, 10:47   #1
Sleeping Dog
Junior User
Car: Evo 4, Apexi filter, 3" Cat back, Ralliart Triple Gauges, HKS Bov
Smile Evo 4 clutch/flywheel question.
A bit of advice needed.
So my E4 clutch is now slipping at higher rpm would like to know what's best to replace it.
I will be using an Exedy organic and will be replacing the flywheel.
Should I use Evo5/6 clutch/ flywheel which I understand is 240mm or an Evo 8 which I've been told is better.
Also would I need any other parts.
Cheers I know this has been proberbly been asked a 1000 times but would rather be sure.
Sleeping Dog is offline   Reply With Quote
Old 22-05-2020, 11:04   #2
McGoo60
I fitted the later clutch and flywheel to my 6, 10mm bigger iirc, I'm running 400bhp and have done track days and its fine.
McGoo60 is online now   Reply With Quote
The Following User Says Thank You to McGoo60 For This Useful Post:
Sleeping Dog (23-05-2020)
Old 22-05-2020, 22:21   #3
2+barplease
2+barplease's Avatar
Car: Porsche 911 C4S + Evo 5 + SL350
Fit the later one, I used an Evo 9 one.
Evo 5 as yet unmodded.....
2+barplease is offline   Reply With Quote
The Following User Says Thank You to 2+barplease For This Useful Post:
Old 23-05-2020, 14:31   #4
Sleeping Dog
Junior User
Later one it is then cheers for the advice.
