Annoying idle - Mitsubishi Lancer Register Forum
Old 12-01-2020, 20:06   #1
Grunter76
Annoying idle
So my 7 has 1 annoying issue im struggling to live with...... Idle is fine rev it stationery and it drops back to base idle fine. However start driving change gear hey presto 2k revs. Pull up at junction 2k tickover. Rev it and it still rests at 2k. Park up and still 2k but slowly it wil drop back down to where it should be. Any ideas or cures. Im 99%certain its not an air leak
Sent from my COL-L29 using Tapatalk
Grunter76 is offline   Reply With Quote
Old 13-01-2020, 10:59   #2
McGoo60
Mine had similar symptoms and I fitted a new ISCV which didn't cure it and it turned out to be an ECU fault with the ISCV control.
Old 13-01-2020, 14:59   #3
r3k1355
I'd start with the idle speed control valve.
Old 13-01-2020, 17:02   #4
Grunter76
I was thinking that...... But in my case its never the simple things
Old 13-01-2020, 22:33   #5
7722adam
7722adam's Avatar
Car: Evo VI GSR, Evo 8 260
Does it only do it when fully at temp? Ie have you driven the car. Stopped it and restarted it when got to see what happens.
I had loads of problems with hunting on idle but only when warm, fine when cold.
Changed all pipe work in case a leak still same, no idle valve and still the same. Changed throttle seals and still the same.
In the end changed the throttle body and maf, not sure what resolved but it did, so might be worth a look, or see if anyone local can swap a known working maf just for a check
Boys never grow up, they just get older and their toys get more expensive, but don't tell the wife that!!
7722adam is offline   Reply With Quote
Old 13-01-2020, 23:00   #6
Grunter76
I havnt tried it at cold to be fair mate by time i get it off the drive its warm. Will have a crack at the weekend
Old 14-01-2020, 08:47   #7
plip1953
Phil
plip1953's Avatar
Car: Evo X RS
Would it be worth hooking up something like a Tactrix cable to monitor the throttle position while the engine is idling normally or at an elevated level? But what I have no idea about is whether the TP position is inclusive or independent of what the ISCV is doing?
Phil
Old 14-01-2020, 09:35   #8
Grunter76
Plip tactrix cable?? Thats a new one to me lol. Ill try anything to cure it as its really annoying lol
Old 14-01-2020, 10:17   #9
TrickyDick
Very Senior User
TrickyDick's Avatar
Car: VII FQ-300x2
Plip is talking about the EvoScan software to monitor the ECU. However could also measure the TPS voltage and ensure its within limits when off the throttle. There will likley be an idle control "hold off" that depends on throttle position and I had this same issue on mine (albeit with ViPec ECU) where is was sitting high just on the threshold and would eventually drop enough for idle control to become active.
TrickyDick is offline   Reply With Quote
Old 14-01-2020, 11:17   #10
plip1953
Phil
plip1953's Avatar
Car: Evo X RS
https://www.tactrix.com/index.php?op...ed=1&Itemid=53
Phil
Old 14-01-2020, 12:33   #11
Grunter76
That seems to sound exactly like whats happening with mine. If it is will it just be a tps adjustment or will i have to book it in
Old 14-01-2020, 15:23   #12
TrickyDick
Very Senior User
TrickyDick's Avatar
Car: VII FQ-300x2
I was able to re-calibrate mine which has been OK since. There is a procedure in the manual to adjust the zero point by rotating the TPS so would be worth trying that before changing the TPS.
Old 14-01-2020, 15:59   #13
Grunter76
Cheers dude ill give that ago. Next question where can i get a manual lol
Old 14-01-2020, 16:12   #14
TrickyDick
Very Senior User
TrickyDick's Avatar
Car: VII FQ-300x2
I'd recommend you join this forum and you can then download tons of info incluidng full maintenace manuals
In the mean time:
Old 14-01-2020, 16:14   #15
Grunter76
In the mean time:
Cheers dude appreciate that. I will join up soon as my bank account has recovered lol
