ABS Delete / Evo 6 / incl. RS Master Cylinder - Mitsubishi Lancer Register Forum
Go Back   Mitsubishi Lancer Register Forum > Marketplace > Wanted
Old 02-01-2020, 10:39   #1
Spilla
Car: Evo 6
Hi guys,
as the title says, I need a complete kit for ABS removal on my Evo 6 GSR. Would be cool if somebody has to offer all of it (master brake cylinder, lines, etc.) at once.
Cheers, Tobi
Spilla is online now   Reply With Quote
Old 05-01-2020, 20:23   #2
Spilla
Car: Evo 6
Does anybody have a clue where to get it?
Old 05-01-2020, 21:02   #3
super rover
acting daft since 1969
super rover's Avatar
Car: E7 RS RALLY CAR
HEL used to do a complete kit for differant types of brake set ups ,may be worth searching about
MY RALLY CARS is SOLD SOLD SOLD SOLD SOLD
<<<<<<<<< THIS
this was my dream rally car but it simply didnt get used poor thing ,now and for the forsealble future EVOLESS
Old 05-01-2020, 21:04   #4
super rover
https://auto.helperformance.com/
ben was allways VERY helpfull
<<<<<<<<< THIS
Old 06-01-2020, 14:00   #5
grants
grants's Avatar
Another to Ben
Spilla
Are fitting a RS diff?
If not you will need to re-wire the ABS and AYC ECUs
Old 06-01-2020, 14:46   #6
McGoo60
Proline do ABS delete kits:
https://www.prolinemotorsport.co.uk/search?q=evo+6
Old 06-01-2020, 15:28   #7
grants
grants's Avatar
Originally Posted by McGoo60 View Post
Have you bought from them ?
Old 06-01-2020, 15:37   #8
McGoo60
Not an ABS kit but have used other hoses from them! don't you rate them then?
Having said that, I've just had another look at the website and the stuff I purchased previously doesn't appear anymore, neither any contact details!!
Old 06-01-2020, 16:16   #9
plip1953
Phil
plip1953's Avatar
Car: Evo X RS
I'm pretty sure Proline are no longer - as of quite recently.
I'm intrigued to know why you would want to get rid of the abs?
Phil
Old 06-01-2020, 20:26   #10
Spilla
Car: Evo 6
Thanks a lot guys! @grants: I already have Evo 9 rs diff and got rid of ayc. My abs isn’t working for 5 years now and I don’t miss it, so I wanted to make the system proper and shed some weight. I will just need new non abs hoses and the non abs master brake cylinder, right? Any kind of help is appreciated! Cheers, Tobi
Old 08-01-2020, 09:27   #11
Spilla
Car: Evo 6
Still need the kit, especially master brake cylinder. Ben from HEL can just help with the lines.
Old 08-01-2020, 11:56   #12
grants
grants's Avatar
I think that the only difference between RS and GSR master cylinders is the bore size.
RS - 1 in diameter
GSR - i i/16 in diameter to suit Brembo calipers?
You will need a proportioning valve to correct front/rear bias, as fitted to RS models see this;
http://evo.parts/index.php?main_page...oducts_id=7291
Old 08-01-2020, 19:57   #13
plip1953
Phil
plip1953's Avatar
Car: Evo X RS
It's certainly not essential to change your master cylinder, although (as pointed out) some kind of proportioning mechanism will be needed. Another option would be the 7RS master cylinder that has rear brake pressure reducers built in.
Bear in mind that (and to most people it's counter-intuitive) the larger the diameter of the master cylinder the greater the pedal effort required to produce a given hydraulic fluid pressure at the caliper pistons, although pedal travel will be reduced.
Phil
Old 08-01-2020, 22:20   #14
super rover
i NEVER fitted any sort of proportioning valve on the rally car standard 2 and 4 port M/C worked just fine ,standard reds all worked perfectly
<<<<<<<<< THIS
Old 08-01-2020, 23:07   #15
evo5d
Car: Evo 5 Tomei forged, Cage, Autronics,VolkSE-37's,Apexi,RS diff,Damd bumper,Varis kit,Ralliart
Near sure I've a proportioning valve in my box, will check and let you know.
evo5d is offline   Reply With Quote
