Hello - Mitsubishi Lancer Register Forum
Old 07-11-2019, 21:46   #1
Tyrone6
Tyrone6's Avatar
Car: Evo 6 GSR Toyota Glanza V X2
Hello
Iíve just ordered some ÷hlins coilovers for my 6
Have you guys coated them before fitting if so what do you use
Many thanks
Ty
Tyrone6 is offline   Reply With Quote
Old 08-11-2019, 10:03   #2
mlau1294
mlau1294's Avatar
I use GT85 prior to fitting coilover socks, and they get a fresh spraying once a year or so depending on how much I've driven her...
Old 08-11-2019, 15:12   #3
JohnT
JohnT's Avatar
Kirkey
https://www.demon-tweeks.com/uk/kirk...-cover-244240/
does the job mighty fine
JohnT is offline   Reply With Quote
Old 08-11-2019, 17:47   #4
mlau1294
mlau1294's Avatar
...or contact Paul (MLR name is "neverneverman") for a set of his coilover socks, top quality and great value for money
Old 08-11-2019, 21:46   #5
Tyrone6
Tyrone6's Avatar
what about cermaic coating them
Old 09-11-2019, 08:25   #6
ClunValleyEvo
Car: Evo Viii FQ300
I would not worry to much about coil overs rusting , everything else will rot out long before a fresh set of coil overs will
ClunValleyEvo is offline   Reply With Quote
Old 09-11-2019, 08:49   #7
plip1953
Phil
plip1953's Avatar
Car: Evo X RS
Isn't there a view that using socks can actually trap moisture inside the sock and cause more damage that way than if left exposed to the elements. Although maybe some of the more expensive socks might be made from a breathable material?
Phil
Old 09-11-2019, 13:09   #8
mlau1294
mlau1294's Avatar
Not heard that one before Phil...
All I can go on is my own experience and Iíve had my Ohlins fitted on my 9 for about 5 years with Paulís coilover socks fitted and GT85.
Theyíve had a few touch ups with GT85 over these years when the cars been serviced but when I look at them now they still look brand new! Also no issues with the coilovers themselves either.
It could because my car is stored in a well insulated garage and only been driven on mice sunny days...
I also have the same system on my 6RS and again the coilovers look sparkling new still and no knocks etc.
So Iím happy with them fitted anyway...
