Bought a bit of a dog evo 4 - Mitsubishi Lancer Register Forum
Old 05-11-2019, 04:45   #1
Evo(v)
Evo(v)'s Avatar
Car: Standard evo iv
I've just bought my first evo, never owned one before so I've a lot to learn, obviously the car looked a lot worse in person but I bought it anyway, it's an evo 4 in scotia white, there isn't a single panel on the car that doesn't have either lacquer peel or surface rust, it feel ok to drive but having said that I can't compare it to anything,
It has 12 month's mot, but I've sent it in to a mot station near me to see if it is legitimate or not, if it isn't I will be contacting the seller and the mot station if I don't get a reasonable response from them I will be contacting vosa? Dvla? I bought a legnum vr4 once with 12 months not that was rotten beyond repair and 3 garages said that it definitely never had a mot a year ago but there was nothing I could do as I couldn't prove it hadn't rotted in my ownership,
One issue I'm concerned about is the idle it hovers around 900 rpm but seems a bit hesitant, when I want to pull away it bogs down, I've tried applying a bit more rpm but seems to kangaroo then fly off?
No cig lighter, easy fix
No reverse light is this on same circuit as lighter socket?
Drivers door cloth peeled away from the door? Strange
Drivers seat is ruined
Water in the driver's foot well which I do need advice on? Not a clue about that?
Going over little pot holes makes my soul want to leave my body, the bangs are sickening like metal on metal no rubber at all,
I'll be sorting paint first then move onto suspension components, starting from bushes if anyone can recommend a full car kit?
I've got brembo front and rear calipers, new drilled/grooved disks front and rear and pads, braided hoses,
Ayc pump has been removed, he cut the pipes and folded them over to stop leaks? Bodge, pump needs a new solenoid, going to relocate to the boot,
Got twins and a house to decorate so this will be an on going thing but respray will hopefully start in 2 weeks time when I'm off,
Evo(v) is offline   Reply With Quote
Old 05-11-2019, 04:48   #2
Evo(v)
Evo(v)'s Avatar
I filled it to the brim drove 351.9 miles and filled it back up to the brim on same fuel it cost £48.66 which I think is really good but I was doing mostly motorway miles at about or slightly below 70 home as I was worried about making it
Old 05-11-2019, 07:38   #3
KarlosDaJackal
Going faster than b4
KarlosDaJackal's Avatar
Location: Sold the house to live in an 8mile long tunnel....
Car: Audi S3 Quattro :D and fully forged 420/420 M.A.D UK WHITE TME
welcome aboard.... sounds like you have your hands full and this EVO is going to keep you busy ! we need some pics.
Every answer you need to fix that car is burried in this site, just get to know that search button well and you would be fine.
>> hhmm..
>>Just a door card thats an easy fix.
>>this is normal - you can get replacement seat / upgrade it or refurb.
>>THat is not a good sign - check all the rubber seals.
>> not good.
>> replace the lot with coilovers and super pro bushes.
>> not normal but it probably had a fault ( most do with age)
Built, Maintained and cared for by M.A.D.....
UK MINT MAK................
The UK TME rare List:https://lancerregister.com/showpost.p...&postcount=530
KarlosDaJackal is offline   Reply With Quote
The Following User Says Thank You to KarlosDaJackal For This Useful Post:
squeakyclean32 (06-11-2019)
Old 05-11-2019, 07:58   #4
LEGNUMVR4
I'd start underneath first with the work.
No point in spending money to have a sparkling turd
LEGNUMVR4 is offline   Reply With Quote
The Following User Says Thank You to LEGNUMVR4 For This Useful Post:
Mita (05-11-2019)
Old 05-11-2019, 08:06   #5
Mita
Hi mate,
Iím confused that youíve done this before and not learnt from it? These cars can be notorious for rust. I would completely forget doing anything else or spending anymore money until youíve been under it properly and assessed the rot.
Evo Ali (05-11-2019)
Old 05-11-2019, 09:40   #6
Evo(v)
Evo(v)'s Avatar
Just this minute got back from an mot, the underneath is solid, I bought it because the mot he put on is about 10 days old so I knew if there was anything major I could go and seek legal action but ifld first approach the garage and give them a chance to rectify it, I will call AMD in Wigan, I've heard good things about them stripping the underneath and redoing it all perfect and in white also,
I'm going to sort the little electrical niggles myself, it has aftermarket headlights at the minute so I'm after some original headlights, ful beam doesn't work at all and side lights,
Only thing I need to do my research on is the driver's footwell filling with water, I had a quick look through the forum but couldn't find anything definitely, I'll have a better look tonight, are seals easy enough to get hold of?
Ordered all 4 front and rear wheel hub bearings, when they arrive they will go on with all the new brake stuff including reflector rings etc
Thanks for the input I'll get pics up later it is a dog I'll be honest but it will get tidied up soon enough
Old 05-11-2019, 09:52   #7
Mita
Windscreen being badly fitted could also be worth checking for footwell leak
Old 05-11-2019, 10:14   #8
david_smith_909
Car: E6
Is it water or coolant?
If coolant - heater matrix or pipes in / around matrix.
If water - check your window and door seals as a starting point
Check your over flow tank / radiator isnt filled with water as well. Could be water from your heater matrix if some idiot didn't used coolant.
David
VI GSR - SOLD
B8 Audi RS4 - 4.2 V8
david_smith_909 is offline   Reply With Quote
Old 05-11-2019, 10:16   #9
Jakeh
Car: 9 Wagon
Here's one route for investigation:
https://www.lancerregister.com/showt...light=footwell
Jakeh is offline   Reply With Quote
The Following User Says Thank You to Jakeh For This Useful Post:
Evo(v) (06-11-2019)
Old 05-11-2019, 10:32   #10
TrickyDick
Very Senior User
TrickyDick's Avatar
Car: VII FQ-300x2
With footwell water the connector blocks in that area often get corroded so worth checking those if you have electric issues. Plenty of contact cleaner should protect them while sorting out water source.
TrickyDick is offline   Reply With Quote
Old 05-11-2019, 12:59   #11
thetyrant
Car: BMW 130i & ST185 GT4 RC - Previously: Evo9-FQ360, Evo5-RS + 2 x Evo2's, all gone but not forgotten.
I would do paintwork last and make sure car is worth painting by going over mechanical's etc first and sorting suspension etc.
First thing is to check for crankwalk if its a still a Evo4 motor?, this is where crank endfloat (side to side movement) is excessive ( max is around 0.4mm but ideally less than 0.2mm) if you have more than 0.4mm it can mean engine is scrap and common issue on Evo4's, best fix is swap in a later model engine.
Good luck with it all and hope you have deep pockets
thetyrant is offline   Reply With Quote
The Following User Says Thank You to thetyrant For This Useful Post:
djmisio85 (05-11-2019)
Old 05-11-2019, 17:15   #12
r3k1355
Have someone run a hose over the car while you're inside, see if any water appears.
Did it pass the MOT with broken headlights and some dodgy knocking noises while driving?
Old 05-11-2019, 23:28   #13
djmisio85
djmisio85's Avatar
Car: Lancer Evo 2 RS
I'm having a similar issue with the car bogging and then flying off in the higher revs, as well as a very jerky throttle on my V GSR.
Am taking it into an evo specialist here in Japan this week, so hopefully they can fix it and I can give you some feedback.
My cig lighter is not working either, but hopefully an easy fix.
Anyways, good luck
djmisio85 is offline   Reply With Quote
The Following User Says Thank You to djmisio85 For This Useful Post:
masTers (06-11-2019)
Old 06-11-2019, 07:46   #14
Aj82
Sounds like you have some work to do but good on you for getting stuck in and going for it.
I did the same and spent alot of time and effort on my 4 before I got the crank walk issue. So worth it to check what codes are on your engine block before doing anything else mate as you might need to buy and fit a later version engine first.
As for the cig lighter, prob a fuse or a damaged wire if it has an aftermarket head unit.
Reverse light could be a bulb, damaged wire or the switch itself on the gearbox but I would guess it had something to do with the water leak you have soaking the connector so check and investigate your leak first.
As for your seat and door card issue, I'm breaking my 4 and have those available in the correct colour etc for sale, just message me if your interested.
Cheers Aj
Aj82 is offline   Reply With Quote
Old 06-11-2019, 10:47   #15
Tom Dick
NR555
Tom Dick's Avatar
Car: Evo VII, forged at NR with a 3076
Seriously, Why TF have you bought it?
If your beliefs bring comfort to your heart, Then who am I to try and tear your world apart? I wish you well in your endeavours and your life, And I'll leave you to yours if you leave me to mine, It's not your place to impose religious law on the rest of us like so many have before, and it's equally not my place to say you're wrong I don't have to read your book and you don't have to like this song
Tom Dick is offline   Reply With Quote
The Following 3 Users Say Thank You to Tom Dick For This Useful Post:
Breen (08-11-2019), gordonm (19-11-2019), Mita (06-11-2019)
