Whats the max power on a walbro 255lph - Mitsubishi Lancer Register Forum
Old 14-10-2019, 11:32   #1
Andygate8
Evo 6 & Evo 9 FQ340
Andygate8's Avatar
It probably been asked a thousand times before, but what power can i safely run on my 9 using a walbro 255lph pump. I have a GT3071R turbo to fit which is well capable of the 500hp im looking for. Spec of the car is as follows
9GT
Norris rod job
tomei 270 cams
1050cc injectors
Link G4+ ECU
Any help or experience would be appreciated.
Andygate8 is offline   Reply With Quote
Old 14-10-2019, 12:50   #2
r3k1355
500 should be ok on a 255, people have ran more.
It's not exactly expensive or difficult to replace with a 340lph tho.
Old 14-10-2019, 16:11   #3
Mark Shead
Car: Evo 6 under construction
Do not try to run it at 500hp as it will be on failing fuel pressure. Only run to 420hp to have any kind of safety in its supply.
Mark
Mark Shead is offline   Reply With Quote
The Following User Says Thank You to Mark Shead For This Useful Post:
grants (14-10-2019)
Old 14-10-2019, 16:54   #4
Andygate8
Evo 6 & Evo 9 FQ340
Andygate8's Avatar
So is a 340lph the recommended for that power then? Want it to be safe
Old 14-10-2019, 17:14   #5
Phil2333
Tarmac Tyre Shredder
Phil2333's Avatar
Car: Evo 6, Forged 2ltr 8MR engine...405/400
I run a walbro 255 at 400/400. Hardwired is the key.
I'd defo run a walbro 400 or 450 at any more power Tho.... Or one of the aeromotive.
My Evo 6 resto thread...
https://www.lancerregister.com/showth...ht=restoration
Phil2333 is online now   Reply With Quote
Old 14-10-2019, 19:15   #6
Andygate8
Evo 6 & Evo 9 FQ340
Andygate8's Avatar
Ok sounds like an upgrade is the best bet then. Which in tank pump shall I go for?
Old 15-10-2019, 09:27   #7
DeltaBoxer
User
DeltaBoxer's Avatar
Car: Mitsubishi Lancer Evo V MR
About 12 volt mate ^_^
Cars Unite People - CUP Gang
DeltaBoxer is offline   Reply With Quote
Old 15-10-2019, 09:34   #8
madmatt
madmatt's Avatar
Actually that's voltage, not power
madmatt is online now   Reply With Quote
Old 16-10-2019, 06:52   #9
nigelS
nigelS's Avatar
Car: Concours Evo VI RS
Walbro 450 Andy
nigelS is offline   Reply With Quote
Old 21-10-2019, 14:26   #10
Grant620
Gizzmo Distributor
Grant620's Avatar
Car: 640hp GTX3576R EVO VI Race Car
Anything over 450, even if hardwired, is not good.
Typically, fuel numbers in the map tend to climb up a mountain at higher RPM with a 255 over 450hp.
Grant620 is offline   Reply With Quote
