Back Again EVO X this time - Mitsubishi Lancer Register Forum
Go Back   Mitsubishi Lancer Register Forum > General Stuff > Newbie
Old 09-10-2019, 15:00   #1
Toby Magic
Car: EVO X 330 GSR
Hi All,
Back again and this time in a EVO X GSR 330
I'm based in Essex so..
Would it still be Rich at RG Motor sport for the EVO X?
Whats the crack with mapping the 10? I used to get LEE5 to do it all for me before in the 8?
Also whats the first things i need to do / check for now?
[IMG][/IMG]
Toby Magic is offline   Reply With Quote
Old 09-10-2019, 21:18   #2
mlau1294
mlau1294's Avatar
Is yours a manual or SST..?
Welcome back into the Evo fold and lovely looking car
Old 10-10-2019, 08:11   #3
Toby Magic
Car: EVO X 330 GSR
Its a manual
and thanks its good to be back
Old 10-10-2019, 08:23   #4
plip1953
Phil
plip1953's Avatar
Car: Evo X RS
Another servicing/tuning option is AP Tuning near Norwich.
There are lots of thread on here about things to check/look out for. One of the first/most important is to ensure the fuel pump relay has been changed. And even if it has, I would still pop in a brand new one just to be on the safe side.
Also, has the timing chain ever been changed? All the early Xs have or once had a chain that can stretch and potentially lead to contact with a vital oil squirter, and if that happens it's likely the end of the engine!
Most other things to look out for would have most relevance before rather than after buying eg has the AYC/ACD pump been replaced? Also, have you had a good look underneath the car, because they are just as prone to rusting as earlier Evos, especially to the subframes.
Hope you enjoy :-)
Phil
Old 10-10-2019, 10:30   #5
Toby Magic
Car: EVO X 330 GSR
Thanks Phil,
Checked the relay and its an old one so gonna order one of them..
Its only done 32000 and haven't got any record of the timing belt or the AYC being replaced
ill get it all checked out next time its in for a service i guess
cheers Toby
Old 10-10-2019, 10:51   #6
Toby Magic
Car: EVO X 330 GSR
Yep was an advisory on the mot that the rear sub frame has some corrosion..
is this something that can be replaced?
Old 11-10-2019, 08:21   #7
plip1953
Phil
plip1953's Avatar
Car: Evo X RS
Originally Posted by Toby Magic View Post
Thanks Phil,
cheers Toby
The X has a timing chain rather than a belt (ie different to all the earlier Evos). Checking for stretch is theoretically possible using a MUT 3 tool, but a more reliable way is to whip off the rocker cover and make a visual inspection from above. A tensioner forces the chain to bulge towards the centre of the engine and it's the extent of that bulge that would give a trained eye all they need to know about how much stretch has occurred. If your pretty certain it hasn't been changed already I would advise cutting to the chase and simply getting it done. A specialist like APT will have done loads of them and therefore have the job down to a fine art. Nevertheless, expect to pay up to £1k!
As a postscript, what year is you car? I think I'm right in saying that the timing chain stretch issue was solved on later manufactured cars, although even those registered in eg 2010 and 2011 were most likely built in 2007 and 2008. The tag on the front seat belt (bottom of B pillar) will confirm.
The AYC/ACD pump is very poorly sited ie just behind the offside rear wheel, and therefore prone to corrosion and premature failure. A new one from Mitsi is (or used to) around £2,000 (£1,674 from RossSport), but there are cheaper alternative options including part exchanging for a refurbed unit or even having your current one rebuilt. The good thing is that the car will still run perfectly ok with the pump removed (but you need clearly need to respect the fact that you don't have AYC or ACD!) and this simplifies going down the lengthier process of opting for a rebuild.
Removing the rear subframe is not an especially difficult job, and it can then be sent away to be shot blasted and powder coated.
Phil
Old 11-10-2019, 09:12   #8
Toby Magic
Car: EVO X 330 GSR
Cool Thanks Phil
I will get all these things checked asap
can you get the ayc pump relocated to the boot or something?
Old 11-10-2019, 09:18   #9
daveyheats
User
daveyheats's Avatar
Beautiful car mate, I nearly bought it myself!
daveyheats is offline   Reply With Quote
Old 11-10-2019, 09:20   #10
plip1953
Phil
plip1953's Avatar
Car: Evo X RS
Cool Thanks Phil
Yes to the pump being re-sited in the boot. Autotorque do a kit, but it's a bit pricey imo (£400ish?), but I'm pretty sure there was a thread from earlier in the year by someone who had made something cheaper.
Phil
Old 11-10-2019, 09:34   #11
Toby Magic
Car: EVO X 330 GSR
this tag?
[IMG][/IMG]
Old 11-10-2019, 09:35   #12
Toby Magic
Car: EVO X 330 GSR
Old 11-10-2019, 09:36   #13
Toby Magic
Car: EVO X 330 GSR
ill try and find it thanks
Old 11-10-2019, 14:53   #14
plip1953
Phil
plip1953's Avatar
Car: Evo X RS
this tag?
[IMG][/IMG]
Yes. So a 2008 build, and therefore the chain should be looked at.
Phil
Old 11-10-2019, 15:53   #15
Toby Magic
Car: EVO X 330 GSR
Thanks Phil
