Best 450-480 hp setups?? - Mitsubishi Lancer Register Forum
Old 20-08-2019, 15:09   #1
iosman123
Hello,
What's the best setup for all round driving fun on a fast road car at around 480hp ?
Best turbo ?
Cams ?
Other mods
What helps in spool and smooth power curves ?
_________________________________
https://bestcordlessvacuumx.com
thanks
iosman
iosman123 is offline   Reply With Quote
Old 20-08-2019, 15:38   #2
plip1953
Phil
plip1953's Avatar
Car: Evo X RS
Originally Posted by iosman123 View Post
Hello,
Best turbo ?
Cams ?
Other mods
thanks
iosman
Having very deep pockets is a good start!
Phil
plip1953 is online now   Reply With Quote
tracker (20-08-2019)
Old 20-08-2019, 19:56   #3
Tyson1991
Do all 450-480bhp setups run like s**t with more aggressive cams?
Tyson1991 is offline   Reply With Quote
Old 20-08-2019, 20:11   #4
mlau1294
mlau1294's Avatar
My 9 runs very sweet even with 272 cams...no lumpy idle or any other "issues" associated with the more aggressive cam profiles...
My car is on Speed Density which might help though..
The Following 2 Users Say Thank You to mlau1294 For This Useful Post:
Stallion (23-08-2019), Tyson1991 (20-08-2019)
Old 20-08-2019, 20:20   #5
mlau1294
mlau1294's Avatar
To the op....
Standard Stage 1 mods, plus:
HKS 7460 - best spool and transient response for this power level
264 cams, though they may not get you to your upper limit number, so 272's may be needed instead
3" Intercooler (ETS?)
Aftermarket exhaust manifold (JMF?)
3" downpipe and TE (C-TEC?)
Injectors (ID1050cc?)
Then of course a rod job / drop-in / full engine out forge...DECENT mapper!!
And to get the best out of the additional power:
Decent brake set-up AND suspension (Ohlins?)
To do it all properly I'd put away at least £10k, maybe budget for up to £15k for any issues found and all those additional parts that you might as upgrade when doing the above...
What Evo do you have by the way? Good luck
The Following 3 Users Say Thank You to mlau1294 For This Useful Post:
MikeC (21-08-2019), Stallion (23-08-2019), Tyson1991 (20-08-2019)
Old 25-08-2019, 10:30   #6
kins
Regional Organiser
kins's Avatar
Car: Evo VI RS
Originally Posted by mlau1294 View Post
To the op....
You could argue the intercooler and exhaust manifold are overkill for that power level. Don't forget about items like the fuel system and clutch though.
Old 25-08-2019, 11:35   #7
kikiturbo
Car: EVO 9 GSR
yeah, a 9 with 272 cams will idle like stock provided it is on speed density... I built one with hks turbo and GSC S2 cams.. idles at 950 rpm and 14.7 AFR no problem..
Old 27-08-2019, 21:16   #8
Tyson1991
Does the 8 with 272 cams idle like stock on speed density?
