Ohlins needing a refurb??? - Mitsubishi Lancer Register Forum
Old 20-08-2019, 11:11   #1
UTH
Car: VI Extreme RS450
Anyone else been through this?
I've not had them THAT long, and given I live in London and don't drive to work I don't exactly put that many miles on the car, not even done a track day in over a year.
Car is currently at the garage with a nasty knock on right lock, and the car in general sounds a bit ropey when going over bumps, so the diagnosis has come back that the shocks most likely need sending off for a refurb.
Does this sound normal for Ohlins or do you think I can kick up a fuss with Ohlins directly? Unfortunately I bought them from someone on the MLR about 4 years ago (can't for the life of me remember who) but they were almost brand news from memory, so not like I was buying a set with 20,000 on them.
UTH is offline   Reply With Quote
Old 20-08-2019, 11:58   #2
plip1953
Phil
plip1953's Avatar
Car: Evo X RS
The recommendation with higher end stuff is to have them serviced at least every couple of years!
Mick Gardner Racing in Barnsley is the place to send them.
Phil
plip1953 is online now   Reply With Quote
darrenevo123 (20-08-2019)
Old 20-08-2019, 12:05   #3
UTH
Oh really?? That's interesting, it never crossed my mind that shocks should be serviced....so I guess this long with no attention could well make it plausible that I'm now ending up with a problem. That's put my mind at rest a bit that this isn't totally out of the blue then, although not ideal that I'm landed with another bill, of course. LOL
Old 20-08-2019, 12:16   #4
Mita
What’s the sort of cost on this?
Old 20-08-2019, 13:36   #5
adamlstr
adamlstr's Avatar
Car: VI GSR, Scotia
My Ohlins are much quieter the more I use the car. If I leave it standing for a few weeks, they're very clunky when I back off the driveway.
adamlstr is offline   Reply With Quote
Old 20-08-2019, 14:40   #6
UTH
The problem I have is that there is a clear very loud knocking noise on hard right lock of the wheel, so there's obviously something wrong somewhere. I'm hoping to hear back from the garage today that perhaps it's not the shocks.....
Old 20-08-2019, 15:36   #7
plip1953
Phil
plip1953's Avatar
Car: Evo X RS
Several hundred quid!
Phil
Mita (20-08-2019)
Old 20-08-2019, 18:42   #8
Nikos!
In Greece they are 100 euro per coilover. If uniballs need replacement (if they knock over bumps) then it's usually an extra 100 per coilover.
I think I need to have them checked end of the year as well.
Sent from my H9436 using Tapatalk
Nikos
@YouTube
Nikos! is offline   Reply With Quote
The Following User Says Thank You to Nikos! For This Useful Post:
Mita (20-08-2019)
Old 20-08-2019, 22:10   #9
ypvs
ypvs's Avatar
Car: Silver 260 . On the up!!
My Cusco zero2 R that i had on my tme did this . I turned out a bit of oil in the top ball joint solved it. Not before i pulled the front diff apart thinking it was the diff bolts....
ypvs is offline   Reply With Quote
Old 28-08-2019, 21:03   #10
Arronevo8
Twin tube suspension has lower oil volumes so a service as from new lots off internal polishing off high points as the suspension works will be floating around. They wont get much heat like competition work.
Old 29-08-2019, 00:15   #11
kikiturbo
Car: EVO 9 GSR
that is interesting as a friend of mine paid something like 1500 EUR for 4 damper overhaul (at official ohlins service point) with one top mount bearing change... and those top mount bearings cost a fortune..
Old 29-08-2019, 09:31   #12
super rover
acting daft since 1969
super rover's Avatar
Car: E7 RS RALLY CAR
weve used sperical bearing in top mounts for years ,we used to use cheap stuff and replace them after ever rally ,some mid event ,we then found a part nuber and supply of GOOD bearing to use but instead of £7 each these where like £60 but we never had an issue again with chattering top mounts
we use this guy whos VERY good hes made dampers for cars we had over time
https://www.facebook.com/GM-Suspensi...6053466442675/
sorry if you dont do faceache
MY RALLY CARS is SOLD SOLD SOLD SOLD SOLD
<<<<<<<<< THIS
this was my dream rally car but it simply didnt get used poor thing ,now and for the forsealble future EVOLESS
Old 29-08-2019, 14:32   #13
kikiturbo
Car: EVO 9 GSR
the R&T shocks use some funny top bearing size that I can not get apart from ohlins, IIRC..
On the stuff I design myself I use Fluro bearings, and their motorsport line and that has served me well
Old 29-08-2019, 18:13   #14
Scaffolder
Scaffolder's Avatar
Car: Evo X RS road / track car
Send a message via MSN to Scaffolder
The manual recommends replacing the top bearing every 10,000 km, with just the bearings being over £100 each from memory
Scaffolder is offline   Reply With Quote
