AYC Pump making some crazy noises when I do a quick direction change. - Mitsubishi Lancer Register Forum
Old 12-08-2019, 19:15   #1
DeltaBoxer
User
DeltaBoxer's Avatar
Car: Mitsubishi Lancer Evo V MR
I am hearing some crazy noises coming from the ass end when I change direction at speed. Seems to like a loud creaking like a hinge that's never been oil after 30 years out in the rain. Is this likely to be a failed AYC pump? I dont have any AYC lights on but I did see it come on last year when it was hot. Any advice would be spot on. I have recently poly bushed and restored the rear end. The diff has fresh oil in it and the suspension seems fine.
Cars Unite People - CUP Gang
DeltaBoxer is offline   Reply With Quote
Old 12-08-2019, 19:17   #2
Evo6er
Evo6er's Avatar
Car: EVO 8 MR
Sounds like AYC fluid needs changing. Did you put the correct oil in?
Instagram @palmaredevo
Evo6er is offline   Reply With Quote
Old 12-08-2019, 20:39   #3
TrickyDick
Very Senior User
TrickyDick's Avatar
Car: VII FQ-300x2
It's likely the AYC clutches are creaking. Usually can be cleared by changing the AYC fluid in the rear diff a couple of times to clean it out. This doesnt need an AYC bleed so is easy to do (although the fill plug is a pig to get to).
TrickyDick is offline   Reply With Quote
Old 12-08-2019, 22:05   #4
DeltaBoxer
User
DeltaBoxer's Avatar
Yes mate got some good stuff from Ross Sport
Old 13-08-2019, 06:12   #5
jhfozzy
S.Wales R.O./Electrician
jhfozzy's Avatar
Car: Evo VI
Did you change both oils in the rear diff?
John
jhfozzy is offline   Reply With Quote
Old 13-08-2019, 10:53   #6
richyx
its the ayc fluid in the diff, and its the clutch plates squeaking
get some ayc fluid and change the clutch bath in the diff, keep repeating the flush until noise has gone
my resto thread
https://www.lancerregister.com/showthread.php?t=490309
richyx is offline   Reply With Quote
Old 14-08-2019, 22:21   #7
sti_this
Agree with richyx, Also richyx I heard you have had success rebuild the solenoids is that true? It's the one part on these pumps that I havent quite figured out how to resolve in house.
sti_this is offline   Reply With Quote
Old 15-08-2019, 17:51   #8
DeltaBoxer
User
DeltaBoxer's Avatar
Excellent, Thanks for the very helpful advice! I will get right on it and let you know how I get on.
Cheers!
