Fast road alignments - Mitsubishi Lancer Register Forum
Old 26-05-2019, 08:42   #1
Aj82
I currently have tein coilover on my 4, with camber top mounts on the front and also camber bolts on the front. I also have polybush castor bushes in the front arms and also polybush bushes in the rear arms.
I'm also running 25mm spacers on 9.5x17 wheels with 235/45/17 ns2r tyres.
I'm about to get some adjustable rear camber arms that I will fit and then attempt full alignment set up.
So Im hoping you guys can provide me with some alignment settings with regard to what camber, castor and toe I should be aiming for.
The car isnt used on track, its mainly my fun weekend blast.
Thanks in advance.
Cheers Aj
Aj82 is offline   Reply With Quote
Old 26-05-2019, 09:09   #2
McGoo60
I've just fitted some ohlins to mine and I found an old thread by Mr Ralliart and found these settings, granted these are for slightly more track orientated but I think I will use these as a starting point.
3 deg negative camber at the front and 1.5 deg rear
1/8" or zero toe at the front, rear zero
maximize caster
Old 26-05-2019, 11:12   #3
Aj82
Yeh iv been looking through a few old threads but as you say they all seem to be track orientated and I'm looking more for a fast road set up.
But thank you for your settings, appreciate the help. The camber seems alittle high for road use though? I would assume the front tyres won't last too long at 3 degrees but I don't know.
Cheers Aj
Old 26-05-2019, 12:21   #4
Rampant
Profound thinker
Rampant's Avatar
Provided you have zero toe, a fair bit of camber won't wear the tyres out unduly.
Aim for -2° front camber or even -2.5° and zero toe and test to see how that suits you.
Je cherche l'orgasme d'auto
J'ai trouve l'orgasme d'auto
The Following User Says Thank You to Rampant For This Useful Post:
Aj82 (26-05-2019)
Old 26-05-2019, 13:57   #5
Aj82
Hi mate. Is that just for the front? What should I be aiming for at the rear? From what I have read zero toe again but what about camber?
Cheers Aj
Old 26-05-2019, 22:49   #6
Rampant
Profound thinker
Rampant's Avatar
Cheers Aj
For the rear, to compliment the fronts suggestion above, I'd suggest -1.5° camber and zero toe.
Cheerz
Mark H
Aj82 (27-05-2019)
Old 27-05-2019, 05:50   #7
Aj82
Appreciate it mate, thanks for the help and will try and get those settings in place and see how it feels.
Cheers Aj
Old 27-05-2019, 06:35   #8
Iceywater
Car: Evo 4.6 GSR (sold), Evo 9 (back :D)
For a fast road setup you can start off with:
Front Camber: -2°
Rear Camber -1°
Front toe: 0°
Rear toe: 0° (-1° might be not bad if the roads you drive on faster sweepers)
Caster: I would leave it original
What tyres are you running and at what pressures?
Iceywater is offline   Reply With Quote
Old 27-05-2019, 06:38   #9
Iceywater
For a fast road setup I would suggest:
Front Camber: -2°
Rear Camber -1°
Front toe: 0°
Caster: I would leave it original for the road
Old 27-05-2019, 09:19   #10
plip1953
Phil
plip1953's Avatar
Car: Evo X RS
Front Camber: -2°
Rear Camber -1°
Front toe: 0°
I can't believe you actually mean -1deg of rear toe (ie -1deg of toeing out) as that would be lethal!! Perhaps you meant -1mm? But even so that's probably not suitable for normal road going car situation.
Phil
Old 27-05-2019, 09:59   #11
kikiturbo
Car: EVO 9 GSR
perhaps he meant 1 deg of toe IN
The Following User Says Thank You to kikiturbo For This Useful Post:
Iceywater (31-05-2019)
Old 27-05-2019, 16:07   #12
Evo6er
Evo6er's Avatar
Car: EVO 8 MR
If it’s a road car and not a track car I’d want a bit of toe in on rear for straight line stability at high speeds.
Instagram @palmaredevo
Evo6er is offline   Reply With Quote
Old 27-05-2019, 17:55   #13
Aj82
I currently have 235/45/17 ns2r on my car and currently running 32psi front and 30psi rear.
So I should be aiming for alittle toe in at the rear, could anyone confirm how much for me?
Cheers Aj
Old 27-05-2019, 17:56   #14
Aj82
Cheers Aj
Old 27-05-2019, 19:10   #15
plip1953
Phil
plip1953's Avatar
Car: Evo X RS
But that equates to 8mm of toe on a 17" or 18" rim!! 1mm is equivalent to 8' (8 minutes or 8/60th of 1 degree) which would be more reasonable.
Phil
Similar Threads
Thinking about a build to around 500bhp. Advice wanted for fast spooling road car. Anees Engine / Turbo 151 17-07-2011 17:51
Kevlar Fast Road Pads - Just £59.99 Delivered! [email protected] Silver Option Traders 1 18-03-2011 00:02
[Evo 10] EXE-TC HDA Fast Road Suspension nigelS Private Sales - Parts 2 22-10-2010 17:38
