ECU connector pins - Mitsubishi Lancer Register Forum
Old 12-05-2019, 14:29   #1
McGoo60
ECU connector pins
Does anyone know if you can buy just the pins for the yellow ECU connectors on a 6, or part number, link etc?
Old 13-05-2019, 13:13   #2
rjwkerkhof
Spoolinup in the US does them
rjwkerkhof is offline   Reply With Quote
The Following User Says Thank You to rjwkerkhof For This Useful Post:
McGoo60 (13-05-2019)
Old 13-05-2019, 13:39   #3
grants
grants's Avatar
So does
https://www.misterconnectors.com.au/...ishi-c31245112
MLR user name Mr Gears
The Following 2 Users Say Thank You to grants For This Useful Post:
McGoo60 (13-05-2019), rjwkerkhof (17-05-2019)
Old 13-05-2019, 15:01   #4
McGoo60
Excellent, thanks both!
Old 15-05-2019, 05:58   #5
madmatt
madmatt's Avatar
Anyone knows the dimensions of the 2 different ECU pins (width x height)?
Old 15-05-2019, 12:27   #6
grants
grants's Avatar
Very similar to the attached
Name:  mx5 contacts.JPG
these are for compatible connector moldings from Tyco. They will not fit OEM moldings due to a different secondary retention device (white bar on side of OEM molding)
Grant
The Following User Says Thank You to grants For This Useful Post:
madmatt (17-05-2019)
Similar Threads
ECU data monitor PSI3(OBD2 Connection) Ben 6 Private Sales - Parts 2 22-07-2009 19:27
Well happy with my Apexi ECU! Podman Trader Discussion 1 17-02-2007 22:55
Motec M800 OEM ECU JamieB Engine / Turbo 2 08-11-2006 15:21
WRC Tech / MLR Sunday Results Mosi Rolling Road Days 40 05-05-2005 19:51
WRC Tech / MLR Saturday Results Mosi Rolling Road Days 30 11-04-2005 16:24
