Why such a massive difference in price for Teins over Ohlins ? - Mitsubishi Lancer Register Forum
Old 10-05-2019, 20:32   #1
shauno
shauno's Avatar
Car: Gunmetal MRFQ360 HKS
So wish to replace my suspension as advised on last service. Also soon to be contacting CR1 for some underside work (thought I could get everything done at the same time)
Personally I feel my car handles perfect for me, ride is a perfect comfort. But the the price of full kit of Bilsteins I can go Coilovers, which I feel most prefer now?
I'm an occasional fine weather driver & attend a few shows each year, car wont be going on track, but want confidence in the suspension if we have a little B-road blast.
Can anyone explain why the large price difference between Teins & Ohlins, are Ohlins really that much better? I've always thought Teins were good quality (never owned any tein suspension before)
Look forward to thoughts, opinions & suggestions
shauno is offline   Reply With Quote
Old 11-05-2019, 07:14   #2
Evo6er
Evo6er's Avatar
Car: EVO 8 MR
Itís like everything in life you get what you pay for. If itís just a B road bomber Iíd consider Bilstein B14ís which are a comfy good quality coilover that arenít as expensive as ohlins.
Instagram @palmaredevo
Evo6er is offline   Reply With Quote
The Following User Says Thank You to Evo6er For This Useful Post:
shauno (11-05-2019)
Old 11-05-2019, 08:17   #3
dreMR
dreMR's Avatar
Iíve got ohlins on mine love them. I do find them hard at slow speeds. I can feel every little bump in the road and change in road surface which is good in a performance car I think.
Iíve been running them at ten clicks from hard as recommended but recently started playing with the settings, currently at 13 clicks from hard and the car feels much better on the road at speed.
I can hold the throttle wide open now on certain bits of road where before I would lift as it felt a bit nervous.
I havenít tried any of the other coilovers to compare though.
dreMR is offline   Reply With Quote
The Following User Says Thank You to dreMR For This Useful Post:
shauno (11-05-2019)
Old 11-05-2019, 08:45   #4
plip1953
Phil
plip1953's Avatar
Car: Evo X RS
Who advised the need to change and why? If the dampers are leaking then of course they need to be replaced, but if they otherwise feel fine to you then why change? Combining the OE dampers with a Tein or Eibach set of lowering springs works very well, and is relatively cheap, but do make sure you get the alignment properly reset after any suspension changes.
Phil
The Following 2 Users Say Thank You to plip1953 For This Useful Post:
Blood Speed (12-05-2019), evo/nut (11-05-2019)
Old 11-05-2019, 08:56   #5
VR-4Squid
Car: CP9A Evolution V
If you are happy with the ride and handling, you're probably best off sticking with what you know works for you.
As for why Tein and Ohlins are at different price points, exchange rates, distributor mark up, differing local production costs, are all a factor. Also are you comparing the same 'spec' product from each? Tein offer everything from budget street suspension up to custom valved, pro-level motorsport stuff, as do Ohlins - are you comparing apples with oranges?
E39A vr-4 - Project 燃えないゴミ (Unburnable Junk) - Stolen!
VR-4Squid is offline   Reply With Quote
The Following User Says Thank You to VR-4Squid For This Useful Post:
shauno (11-05-2019)
Old 11-05-2019, 09:01   #6
shauno
shauno's Avatar
Possibly yes, havenít looked into the spec of each to be honest, just doing a quick look last night
Old 11-05-2019, 10:19   #7
TrickyDick
Very Senior User
TrickyDick's Avatar
Car: VII FQ-300x2
Your signature says you are talking MR FQ 360 in which case I'd stick to the OE suspension and just replace/repair what is needed especially for road use only. Having had an MR (which I miss dearly!) and also worked through various "upgrades" you will ruin a great ride unless you are wanting a move to a more track oriented solution and a much bumpier experience on the road.
TrickyDick is offline   Reply With Quote
The Following 3 Users Say Thank You to TrickyDick For This Useful Post:
dreMR (11-05-2019), plip1953 (11-05-2019), shauno (11-05-2019)
Old 11-05-2019, 11:39   #8
shauno
shauno's Avatar
That was my first worry / thought. The current ride is superb. More homework needed
Old 11-05-2019, 12:40   #9
TrickyDick
Very Senior User
TrickyDick's Avatar
Car: VII FQ-300x2
definitely worth looking into Bilstein service and replacement springs if needed - good luck
Old 11-05-2019, 13:38   #10
Gav33
Personally I would just refurb the original suspension. I prefer oem parts. After all Mitsubishi must have done a lot of research and testing to get the best setup.
Evo IX MR FQ 360 no: 092
Gav33 is offline   Reply With Quote
The Following User Says Thank You to Gav33 For This Useful Post:
shauno (11-05-2019)
Old 11-05-2019, 14:30   #11
McGoo60
yes but the best setup for what? OEM setup is probably a compromise of handling comfort, cost etc to suit the average driver in average conditions.
The Following 2 Users Say Thank You to McGoo60 For This Useful Post:
Evo6er (12-05-2019), shauno (11-05-2019)
Old 11-05-2019, 20:43   #12
Gav33
Exactly for that setup. Spirited driving every now and again and comfort for when Iím not. No track days. So for me the current standard setup is perfect.
shauno (12-05-2019)
Old 11-05-2019, 21:37   #13
madspeed
Ohlins probably did more research than Mits. Thats all they do - suspension R&D.
madspeed is offline   Reply With Quote
The Following User Says Thank You to madspeed For This Useful Post:
Geoffski74 (15-05-2019)
Old 12-05-2019, 04:59   #14
super rover
acting daft since 1969
super rover's Avatar
Car: E7 RS RALLY CAR
not really ,OE stuff has just the one setting which means it has to be fairly well tuned to nail down a perinent setting ,with any adjustable damper there millions of combinations with bump and rebound settings ,a luxury standard dampers dont have
ive allways said a single rate damper will allways drive better than even the best and most expensive damper IF youve no idea how to set it up and what to set to allow you to tune it better
The Following User Says Thank You to super rover For This Useful Post:
shauno (12-05-2019)
Old 12-05-2019, 08:58   #15
TrickyDick
Very Senior User
TrickyDick's Avatar
Car: VII FQ-300x2
and not forgetting the appropriate spring rates ...
Similar Threads
Ohlins Road and Track mini-review Grant620 GB Enterprises 33 26-06-2018 13:27
Jap Spec Ohlins Price?? tofulo Suspension / Handling 2 21-08-2012 15:01
price difference EGK Lancer Chat 21 19-11-2004 13:07
