Evo 6 gearbox mount whine noise - Mitsubishi Lancer Register Forum
Old 30-04-2019, 05:28   #1
TMEEMT
Just after some advice from more experienced members.
Briefly - low mileage 6.5 fully serviced. The car has a loud whining noise from the front passenger side (RHD car), when higher in the revs on deceleration.
It doesnít make the sound when accelerating nor when the load is removed by pushing the clutch pedal in.
Before I go dropping the tfer case/gearbox, has anyone had experience with such a loud noise, due to a worn out gearbox mount?
The tfer case has been dropped and checked no issues.
Any advice appreciated before I start paying out $$. Btw Iíve had an experienced Evo guy steer me this way just wanted members feedback.
Thanks.
TMEEMT is offline   Reply With Quote
Old 30-04-2019, 05:45   #2
TMEEMT
Also it appears the gearbox mount (if itís that) which is making the noise is the mount nearest the cabin on passenger side.
The car is factory, no mods. Cheers.
Old 30-04-2019, 06:42   #3
super rover
acting daft since 1969
super rover's Avatar
Car: E7 RS RALLY CAR
youd only get a noise from a mounting if its failing but not a whine ,it would CLUNK , ,it isnt hard to cheak ,but there could be allsorts of reasons ,if its in that area id say its likely it be gearbox end ,whines are moving part noises
Old 30-04-2019, 06:55   #4
TMEEMT
Ok thanks for that sounds logical. The Evo guy that drove and listened to it mentioned gearbox, but thought it was more the gearbox mount and the loud vibrations that came from that specific area. (The sound is a vibration/drone noise actually). Possible?
Old 30-04-2019, 08:41   #5
sion_kwl
User
I have a similar noise in my 4, I've read theories ranging from transfer box to springs on the clutch... I've checked everything I can without actually dismantling the box and transfer case... I've decided to ignore it till something breaks
sion_kwl is offline   Reply With Quote
The Following 3 Users Say Thank You to sion_kwl For This Useful Post:
big S (02-05-2019), TMEEMT (01-05-2019), VR-4Squid (17-05-2019)
Old 30-04-2019, 09:00   #6
Evo6er
Evo6er's Avatar
Car: EVO 8 MR
1st port of call would be to run fresh fluids through everything and see if the issue is still there
Instagram @palmaredevo
Evo6er is offline   Reply With Quote
Old 01-05-2019, 20:50   #7
VI_Shooter
Regional Organiser
VI_Shooter's Avatar
Car: Stock Silver VI GSR from Nippon!
It's not the PAS pump is it? Maybe needs new fluid?
"Do not meddle in the affairs of Lancers, for they are rally and quick to 60"
VI_Shooter is offline   Reply With Quote
Old 01-05-2019, 22:28   #8
TMEEMT
Yes have replaces all fluids 2 weeks ago noise is still there. Will get it put on a hoist next week will report back.
If anyone has any other ideas itíd be great to hear. Thanks.
Old 14-05-2019, 17:32   #9
war-machine
war-machine's Avatar
Car: evo 7 rs
Who actually is the evo guy sounds like he aint got a clue...
Old 15-05-2019, 06:04   #10
madmatt
madmatt's Avatar
I also have a whine on my Evo 6 tme when coasting. Haven't really looked at it yet, but I would think probably transfert box bearing or something like that. I'm interested to know if you're gonna find the issue. Its not really bothering me yet, but its definitely something that on its way out. However my car's got around 80k miles.
Old 15-05-2019, 13:41   #11
TMEEMT
Just an update. Under the car looking up when on a hoist there is a metal torsion bar. That was slightly bent and was hitting the exhaust. This was creating a resonance noise. I removed it and drove the car, it was slightly less loud but the deceleration noise was still there. Am having diagnostics done this week will advise outcome.
Checked all gearbox/engine mounts theyíre all good.
Old 15-05-2019, 14:36   #12
kes205
Car: EVO VI GSR
Keep us updated as mine does the same thing occasionally and would be great to find out the fix.
kes205 is offline   Reply With Quote
Old 16-05-2019, 05:15   #13
TMEEMT
Ok so had a full diagnostics and sensors and even an audio tracking aid fitted all over the car. Main noise area is left side (passenger on RHD), gearbox. Stripping required to ascertain but at least have narrowed down the noise location.
Similar Threads
Stolen Evo's marksmart Lancer Chat 309 28-11-2017 08:42
Brake and Clutch Lines By HEL Performance BHP MLR Group Buys 455 06-11-2011 05:47
Sti or evo 6 Bakerboy Lancer Chat 42 12-08-2011 19:11
