Brembro help to split callipers - Mitsubishi Lancer Register Forum
Go Back   Mitsubishi Lancer Register Forum > Technical > Brakes
Old 20-03-2019, 23:10   #1
Ssbd7
Junior User
Car: 1999 Evo 6 icellar blue
Trying to split these callipers for refurbishment but canít budget these bolts, was going to drill the heads of and try it that way, unless anyone can help otherwise, but if I do drill them out where can I get replacement bolts from,,,
Cheers allName:  D44C0153-5737-44B5-AF73-F0175624DF01.jpeg
Ssbd7 is offline   Reply With Quote
Old 20-03-2019, 23:16   #2
Edkeo
You can get rebuild kits for them but if I was you I’d be looking for a decent second hand set
Edkeo is offline   Reply With Quote
Old 20-03-2019, 23:45   #3
Ssbd7
Junior User
I’m going to get them vapour blasted then powder coated, but having difficulty splitting them, the bolts are solid, any ideas where to get new bolts
Old 21-03-2019, 00:41   #4
LEGNUMVR4
Originally Posted by Ssbd7 View Post
Iím going to get them vapour blasted then powder coated, but having difficulty splitting them, the bolts are solid, any ideas where to get new bolts
Try and heat the area around the bolt gently with a heat gun .
Don't use a blow torch
LEGNUMVR4 is offline   Reply With Quote
Old 21-03-2019, 08:59   #5
Ssbd7
Junior User
Be there all day with a heat gun haha...going to try again today but heat the opposite side where the thread is hopefully get some movement, if not I’ll drill the heads of them
Old 21-03-2019, 12:57   #6
Dave-Cee
Climate Changer
Dave-Cee's Avatar
Car: MAD forged 2.2 IX FQ 340 PLG Leccy Bloo
Heat gun will be no good. It's fine to use a torch, MAP gas is what I use in situations like this. Alloy melts at over 700 Deg so long as you don't hold the heat on it for a very long time it's fine.
Support the calliper in a vice, heat up the area around the bolt but avoid the bolt as much as possible as you're looking at heating up the alloy which expands quicker than steel. I haven't mentioned minding the seals as I'm sure they are being replaced
It will also help to give the bolt a short sharp wack with something like a 3/4 ratchet extension on the the head. I'm assuming here that the hex in the head is in a decent enough condition.
If you've rounded the bolts at all then it's drilling time and easy outs etc . But still use the heat method.
Finding the bolts is the least of your problems they are ten a penny.
Good luck... its all doable.
Dave-Cee is offline   Reply With Quote
The Following 2 Users Say Thank You to Dave-Cee For This Useful Post:
MikeC (24-03-2019), Ssbd7 (03-04-2019)
Old 03-04-2019, 20:44   #7
Ssbd7
Junior User
Great info mate ,, but unfortunately broke a bleed nipple flush trying to take it of so now currently trying to drill out and use a tap and dye set to re thread the thing,,,where’s the best place to get the new bolts for callipers
Old 24-04-2019, 02:49   #8
war-machine
war-machine's Avatar
Car: evo 7 rs
Great info mate ,, but unfortunately broke a bleed nipple flush trying to take it of so now currently trying to drill out and use a tap and dye set to re thread the thing,,,whereís the best place to get the new bolts for callipers
i know Where you can source the bolts !
ill leave the contact info...
contact you tomorrow
Old 24-04-2019, 21:05   #9
andymrfq320
andymrfq320's Avatar
i put a long bar on beefy allen key and cracked them with the caliper in a vice.
i'm gussing you've probably already tried that though?
andymrfq320 is offline   Reply With Quote
Old 25-04-2019, 00:14   #10
Dave-Cee
Climate Changer
Dave-Cee's Avatar
How did you break a bleed nipple trying to split 2 calliper halves ?
Old 25-04-2019, 04:03   #11
war-machine
Car: evo 7 rs
i use heat before i use the spanner...don't go mad with the blow lamp...works a treat
Old 30-06-2019, 20:02   #12
Ssbd7
Junior User
Because I tried to remove the bleed nipple to replace it , it wasn’t due to trying to separate the callipers, I thought we were clued up on this form haha
Similar Threads
Changing callipers 6evo Brakes 5 02-03-2018 20:41
Evo 6 with E9 callipers - offset help? Doodley Tyres / Wheels 4 27-09-2012 18:07
E8 HID headlights split - detango'd & blacked GrahamH Picture & Video Gallery 27 24-05-2012 10:02
Help OZ Split Rims Jone Tyres / Wheels 0 12-01-2006 20:41
Callipers on the V and VI...? madgerald Brakes 2 20-11-2004 18:23
