Water Overheating wsith Top Mount - Mitsubishi Lancer Register Forum
Old 26-07-2018, 10:40   #1
Lolo la Torche
Senior French User
Lolo la Torche's Avatar
Car: Full Black Evo IX 600HP+
Hi All,
Last Week end we mount and set up a 7670 Top mount Kit instead of my 7163 on my 2 litres forged engine.
Down and manifold were wrapped, Turbo has its own blanket. Car still have AC and runs an Evo 6 OEM water radiator.
Oil rad is a 26 Row Setrab.
Car is now 625HP and 680nm.
We tried the car on the Castellet last saterday. It was 29°C. For the first time, with full boost (2.2B), I have water overheating in 3 laps (114°C). Head Gasket is OK, I Don't loose too much water and if I put down the boost to 1.8B, the car doesn't overheat anymore (so no overpressure)
I know that more power means more heat...I would like to keep AC, so what serious options do I have to solve this?
I was thinking to add a radiator on the cooling of the turbo?
Lolo la Torche is offline   Reply With Quote
Old 26-07-2018, 10:53   #2
strange_days_uk
Simon - EVO V
strange_days_uk's Avatar
Car: EVO V
Do you have uprated oil coolers?
Also, can you not install an uprated radiator? Does this cause problem with AC location?
Perhaps a high flow water pump?
http://www.ap-tuning.co.uk/
Originally Posted by Aidy View Post
Most TME owners have never driven an evo, including their own.
strange_days_uk is offline   Reply With Quote
Old 26-07-2018, 12:02   #3
swinks
swinks's Avatar
Car: ex-Mitsubishi Galant VR4, Mitsubishi Lancer Evolution 8 FQ300
Send a message via Skype™ to swinks
If it's so much boost related, you may suffer headlift issue.
ex-Galant VR4: 269 WHP and 325 LbFt torque at 0.9 bar (stock engine, turbo and ecu)
Evo 8 FQ300: 325 WHP and 375 LbFt torque at 1.6 bar
swinks is offline   Reply With Quote
Old 26-07-2018, 12:10   #4
Lolo la Torche
Senior French User
Yes the oil cooler is upgraded. As I wrote, it is a 25 row Setrab.
I’m afraid a bigger radiator won’t have enough place to be mount.
Upgrated pump? Too late? Mine is new, it has 150 km including dyno settings ��
Old 26-07-2018, 12:12   #5
Lolo la Torche
Senior French User
Yes, it’s boost related, but on the Motec logs, we can see a step by step temp increase. It doesn’t look like water is pushed, and a very little water is missing.
Old 26-07-2018, 16:07   #6
grants
grants's Avatar
Are you still using the OEM radiator and A/C fans, and is radiator fan running a maximum speed?
I don't think adding a turbo "radiator" is worth the effort? It would be worth checking for any airlocks in the turbo plumbing
Old 26-07-2018, 16:09   #7
Lolo la Torche
Senior French User
I have the AC OEM radiator, OEM Evo 6 Water Radiator and slim Revotec Comex high perf FAN
What does airlock in the turbo means? better heat extration from turbo?
Old 26-07-2018, 17:00   #8
kikiturbo
Car: EVO 9 GSR
I would first check for traces of exhaust gas in the coolant, just to rule out head lift..
Old 27-07-2018, 11:25   #9
2+barplease
2+barplease's Avatar
Car: RVR Evo 6.5 2.0 L/R by Norris Designs
I had a similar problem with my RVR, its got a Norris 2.0LR and I'm only running a 9.5T blower but found on a hot summers day the temps rising too much for my personal taste.
So to solve it I had a radiator made with a 1/3rd more capacity, now it runs max 82c with an outside air temp of 30+. In normal weather it runs at 75c.
I also run a OEM E9 Oil cooler and my oil temps dont go above 90 on full tilt.
Oh the rad cost about £400
Forged RVR Evo 6.5 380/400 @ 1.6bar on SD
2+barplease is offline   Reply With Quote
Old 27-07-2018, 13:16   #10
strange_days_uk
Simon - EVO V
Car: EVO V
That sounds like a very interesting proposition. Mine runs a Koyo rad but I very often front the temps creeping up, a little too much for my personal taste also.
Who/Where did get the custom rad done? Was it based on an OEM rad?
Old 27-07-2018, 14:34   #11
Shakey_Jake188
Shakey_Jake188's Avatar
Car: BRSCC Mazda mx5 Race Car #188, Evo 6 Tommi Makinen Edition and Evo 5 GSR
Standard radiators work well providing they are in good condition.
What headstuds are you using?
600bhp+++ Evo 6 TME Road & Sprint Beast
https://www.lancerregister.com/showthread.php?t=535560
Shakey_Jake188 is offline   Reply With Quote
Old 27-07-2018, 14:37   #12
Lolo la Torche
Senior French User
ARP Ones
Old 28-07-2018, 11:14   #13
2+barplease
[QUOTE=Lolo la Torche;6114188]I had a Koyo on my list, but as you can see on the engine bay pic, I'm not sure it can fit with a top mount turbo, there are no space…
2+Bar, do you have AC?
No I had to delete it to fit the fans.
I'll have a measure up on Sunday and give you size, plus I'll dig out the invoice by the firm who made it.
Oh I run 2 x Slimline fans, one pushing one pulling.
The Following User Says Thank You to 2+barplease For This Useful Post:
Lolo la Torche (29-07-2018)
Old 28-07-2018, 11:22   #14
2+barplease
It is based on an OEM rad yes, I sent my oem rad to them so the locating pins would be in the correct place and they made me a new one slightly wider and thicker core. Works really well, on the M25 on a hot day 30ish my water temps stay low. in fact i have a pic on my phone of my gauges on the m25 just recently.intake air temp is 36c so hot outside, my water temp 73c oil temp 81c thats at about 80mph.
The Following 2 Users Say Thank You to 2+barplease For This Useful Post:
Lolo la Torche (29-07-2018), strange_days_uk (28-07-2018)
Old 29-07-2018, 11:37   #15
Lolo la Torche
Senior French User
Ok, that sound's interesting but I have no overheating except on track days, so hard use, will more than 2 bar turbo boost.
At a constant 80mph, I have no overheating problem
At high speed, a fan decrease rad efficiency ,it acts like a barier and blocks air flow
