auxillary belt tensioner - Mitsubishi Lancer Register Forum
Old 26-05-2010, 18:16   #1
evo-jay1
done a search and came accross this thread
https://www.lancerregister.com/showth...=aux+tensioner
not yet tried it but i cant budge my tensioner with a 1/2 " ratchet in the hole is it possible to get it off and soak it in wd to get it working again so i can get a bearing sorted or is it a case of new complete tensioner
thanks in advance
If its got tits,tires and a turbo its going to cost you
evo-jay1 is offline   Reply With Quote
Old 26-05-2010, 18:23   #2
stu8
stu8's Avatar
Car: Evo V - geekmapped.com
thanks in advance
just checking, are you putting the square end of then 1/2" extension in the square hole and moving it the correct way?
Stu
CPP Motor Developments -
RG Motorsport -
Old 26-05-2010, 18:31   #3
matthew1873
Car: Evo IV, standardish..............
Counter clockwise mate, they are tight to move. Only moves just over an inch 'till the holes at the bottom of the unit meet up to pin.
Have you checked to see how tight the belt is also?
Back in another Evo again
matthew1873 is offline   Reply With Quote
Old 26-05-2010, 18:38   #4
evo-jay1
stu yer putting the square end in and just wont budge,the belt is tight it just makes that horrid noise when cold as described in the other thread i pasted on this 1 so thought id change the bearing or get it off so can check it, is there any other way of getting it off ie by taking the belt off somewhere else to get the tensioner off to free it up
Old 26-05-2010, 18:48   #5
stu8
stu8's Avatar
have you tried moving it both ways, its a while since i did mine, but i remember initially trying to turn it the worng way
Stu
RG Motorsport -
Old 26-05-2010, 18:51   #6
evo-jay1
no i aint mate to be honest just a bit frightened of breaking the casting as it just wont move at all,thinking of taking belt off by either removing another pully and then undoing the tensioner at mo
Old 26-05-2010, 18:56   #7
stu8
stu8's Avatar
i doubt you'll break anything with just a ratchet, unless it is already broke
Stu
RG Motorsport -
Old 26-05-2010, 19:11   #8
straightliner
Car: Evo 6 GSR
you could just remove the whole assembly and free it up just undo the two bolts the main bolt 13mm iirc and the other shorter one to the right on this pic
straightliner is offline   Reply With Quote
Old 26-05-2010, 19:34   #9
evo-jay1
cheers mate thats wot i gonna do as it wont budge at all
thanks to every 1
Old 26-05-2010, 19:47   #10
K70MAK
Car: Ex Essien Grey Evo 7, now Self Built Forged 2.0 Evo 4 Sprint Car
I have done the bearing change as per the link in the first post on my evo7 when it started making a noise, simple fix, think the bearing only cost a about £3 from a local bearing supplier.
K70MAK is offline   Reply With Quote
Old 26-05-2010, 19:52   #11
evo-jay1
can only find 1 12mm bolt that holds it on which is the one above the oil filter and just goes tight and feels like it gonna ring off so il try it again when engine run a bit to get a bit of heat in it, cant find any other bolt other than the 14mm one that goes through centre of bearing can some 1 show me where exactly the bolts are pleeeeease
Old 26-05-2010, 19:58   #12
straightliner
Car: Evo 6 GSR
already said , the large one in the middle and the one to the right
Old 26-05-2010, 19:59   #13
evo-jay1
ahhh sorry didnt read it right will have a go tomoz as getting dark now and soaked it in wd will get a bearing tomorro as got got the number off that other thread
Old 29-06-2011, 14:39   #14
hrg
Car: Evo 6 TME
so i changed the bearing myself (and it was ********ed when I took it out) but I still have an annoying squeek/rattle at low revs but only when the cars WARM... any ideas guys?
hrg is offline   Reply With Quote
Old 21-07-2011, 20:25   #15
hrg
Car: Evo 6 TME
fitted a new tensioner and BINGO, sorted
