evo V gearbox noise - Mitsubishi Lancer Register Forum
Old 04-09-2019, 21:26   #1
luca wrx
Car: lancer evolution RS
Question evo V gearbox noise
hello i try to explain my problem that makes me crazy...
i owned 2 evo (all with the normal 5speed gearbox) and all of these cars make this noise from the gearbox...
it is like a bearing noise (rattle) from the gearbox
i tryed to change the gearbox oil , clutch bearing, clutch and flywheel but the noise doesn't change...
i would like to know if somebody has had the same problem or has experience with this noise
thanks guys for your help
evolution VI RS
luca wrx is offline   Reply With Quote
Old 06-09-2019, 14:50   #2
DeltaBoxer
User
DeltaBoxer's Avatar
Car: Mitsubishi Lancer Evo V MR
Are you sure its the gear box and not the transfer case ? If your shifting gears ok and there are no problems Id say that there is probably an issue with the transfer case diff.
Cars Unite People - CUP Gang
DeltaBoxer is offline   Reply With Quote
Old 07-09-2019, 11:17   #3
luca wrx
hello mate, yes i can shift all gears perfecty without problem
yesterday i made a test, i lifted the car and i shifted some gears 1-2-3 and after 4.000 rpm (like the video) underside the car i heard the noise only from gearbox...not the transfer
i really don't know, if the gear bearings can make this...but i think that the only way is to open the gearbox and ceck all parts...
evolution VI RS
Old 12-09-2019, 13:51   #4
Clivew
Transmission Dynamics
Clivew's Avatar
What exact clutch are you using?
[email protected]
Old 12-09-2019, 16:35   #5
luca wrx
hello Clive, i changed the clutch some month ago, but the noise is always the same
the first clutch and flywheel was the oem, after this i installed a new cusco hyper single with a new oem bearing with millers gearbox oil
evolution VI RS
Old 13-09-2019, 20:34   #6
ondafly
heat shield or loose 02 sensor on the exhaust ?
ondafly is offline   Reply With Quote
Old 14-09-2019, 21:10   #7
Clivew
Clivew's Avatar
It sounds like resonance, is the engine standard?
[email protected]
Old 16-09-2019, 20:09   #8
luca wrx
thanks mate for the idea, just checked, but it's all ok with all bolts
evolution VI RS
The Following User Says Thank You to luca wrx For This Useful Post:
ondafly (17-09-2019)
Old 16-09-2019, 20:31   #9
luca wrx
yes i think the same, but it's very strange....!
the engine is standard (only with HKS 264cam)
can the gearbox bearings make this noise for you?
i put the car on jack lift and i tried to listen the noise under the car in acceleration and deceleration but no vibration founded...
only noise that i can hear only from inside gearbox...
i made this video:
evolution VI RS
Old 25-09-2019, 06:53   #10
Clivew
Clivew's Avatar
You don't normally get a resonance type noise from inside the gearbox because the oil dampens noises of that frequency. The noise in the 2nd video doesn't sound right though.
[email protected]
luca wrx (10-10-2019)
Old 26-09-2019, 21:59   #11
evowilly
Car: Evo V & clio Williams
Have you tried accelerating with no gear inserted? Does it make that noise?
Enviado desde mi SM-G920F mediante Tapatalk
evowilly is offline   Reply With Quote
Old 10-10-2019, 20:06   #12
luca wrx
some news: i removed the gearbox and i changed all bearings , but the noise is always the same from the box in deceleration....
and when i press the clutch the noise disappears...
the tuner told me that the gears are wear and they can make this noise but it's strange...a vibration from gears...
evolution VI RS
Old 10-10-2019, 20:09   #13
luca wrx
yes i tried mate, without gear inserted there is no noise
evolution VI RS
