EVO 6 / 4G63 - re-torque of OEM head bolts possible? - Mitsubishi Lancer Register Forum
Old 25-03-2019, 05:59   #1
sebu
Hello,
lately my head gasket is leaking oil to the front of the engine. Behind the exhaust manifold in the area of the 1st Cylinder.
I did a compression test and internally the engine seems to be fine. (1350, 1310, 1310, 1310 kpa) No water in oil and vice versa. Also the amount of oil its leaking is small, but noticeable on the dipstick.
Worst case I will have to replace the head gasket, but if possible I would like to try what has been recommended to me: Re-torque the head bolts.
I know the OEM head bolts for the 4G63 are stretch type. So general question here is, is it even possible to re-torque such bolts? Some say yes, with about 100Nm and circle pattern (inside-out). Is that true?
I think if they have stretched because of too high engine load / boost, it might be possible to fix the leakage temporary with re-tightening. (I am aware it will happen again if that is actually the case)
best regards,
Sebastian
sebu is offline   Reply With Quote
Old 25-03-2019, 07:46   #2
plip1953
Phil
plip1953's Avatar
Car: Evo X RS
What I can tell you, purely from my experience of being a customer of an engine builder on multiple occasions, is that a head would be torqued initially and then re-torqued after a relatively short period of usage. Whether this is the optimal approach, or simply the chosen path of my particular engine builder, I really don't know. And I have also known a head be re-torqued if signs of head lift if have detected (which generally showed as cylinder pressure leaking into the cooling system ie rather than in any way oil related). But that was more as temporary measure to get through an event rather than as a long-term fix.
Phil
Old 25-03-2019, 09:54   #3
Clivew
Transmission Dynamics
Clivew's Avatar
It sounds like one of the exhaust manifold studs has lost it’s seal, these encroach into oilways in the head, so if the sealant fails, it will leak oil.
I’d remove the studs around the area of the leak, deagrease the internal thread, and re-fit the stud with high temp sealant.
[email protected]
The Following 4 Users Say Thank You to Clivew For This Useful Post:
alpinaturbo (25-03-2019), fletchbog (02-04-2019), Mita (25-03-2019), sebu (26-03-2019)
Old 25-03-2019, 10:32   #4
TrickyDick
Very Senior User
TrickyDick's Avatar
Car: VII FQ-300x2
Clive is spot on. Here's what my stud leak looked like. Oil seems to make its way around the gasket line and make it look more serious than it is. A couple of my studs are quite loose and it needed a good wrap of ptfe (plumbers) tape plus sealant to stop the leak. New studs are a good idea too.
TrickyDick is offline   Reply With Quote
The Following 2 Users Say Thank You to TrickyDick For This Useful Post:
Clivew (25-03-2019), sebu (26-03-2019)
Old 26-03-2019, 05:31   #5
sebu
Is that a thing!?
Of course I will give this a shot first. I have to replace my exhaust manifold anyways (again) as it has a crack. Any recommendations for the sealant to use? Can I use the same as for the valve cover? Plumbers tape I would like to avoid...
Or should new studs already be fine without the sealant?
Just to get back to topic. In case my stud seals are fine I would still go and try the re-torquing before getting the engine torn apart. I was recommended to use 100Nm for re-torquing as the angle torquing can not be applied. Can anybody comment on this?
Old 27-03-2019, 16:57   #6
Clivew
Clivew's Avatar
Is this a thing? No, we’re all making it up to give you the run around. Please don’t insult us.
Back on topic?
We are discussing the topic of the oil leak and the most likely cause.
You said comp tests are fine, so why do you want to ‘tear the engine down’ ?
If I were you, I’d remove the exhaust studs, degrease the threads in the head, then re-fit, coating the threads in red RTV or Loctite 5990 or similar.
I wouldn’t touch the head bolts until you know the head gasket is the cause, and even then, if it is, you’ll want to fit a new gasket, so a re-torque of the head bolts is mute.
A final note anyway - the standard head bolts cannot be further tightened once fitted, you need to remove, check they have not permanently stretched (nominal length 99.4mm), re-oil the threads, then re-torque and tighten another 180deg.
[email protected]
Arronevo8 (27-03-2019), fletchbog (02-04-2019), Mita (27-03-2019), Tom Dick (27-03-2019)
Old 27-03-2019, 17:05   #7
Arronevo8
Oh! Clive I love it when your forceful
Old 28-03-2019, 05:29   #8
sebu
I wasn't saying I am not going to do the studs first. I was only getting back to the topic which is not regarding the oil leak itself but the question if one can re-torque the head bolts. If I don't have to do it, great, but I was thinking anybody looking at this topic later on might also want to have that info, me included. - maybe I was too thoughtful
anyways, thx for the extra info. So I know now that just re-torquing without pulling them might cause more issues than provide a solution.
An additional question regarding that: Can you pull one by one or could this cause head warp or leakage and then I'd have to pull the head off anyways? I read people switching to ARP have done it one by one but it sounds scary to me.
Old 28-03-2019, 08:37   #9
Clivew
Clivew's Avatar
Yes, remove and re-torque one by one, in the same order as the original torque pattern, nothing will warp I can assure you, as only one bolt is loose at a time.
[email protected]
Old 30-12-2019, 13:15   #10
peklein
Hello,
Worst case I will have to replace the head gasket, but if possible MyColes I would like to try what has been recommended to me: Re-torque the head bolts.
best regards,
Sebastian
I also need the same suggestion.
peklein is offline   Reply With Quote
Similar Threads
Stolen Evo's marksmart Lancer Chat 309 28-11-2017 08:42
Evo numbers by model and colour Aidy Lancer Chat 54 31-10-2016 19:17
Brake and Clutch Lines By HEL Performance BHP MLR Group Buys 455 06-11-2011 05:47
LED Side & Foglight Group Buy from Xenonshop BHP MLR Group Buys 576 30-03-2011 12:05
