Fault codes on a X - Page 2 - Mitsubishi Lancer Register Forum
Old 07-01-2018, 20:00   #16
Sider
Sider's Avatar
Originally Posted by stu8 View Post
just seen the prices of genuine sensors on the Rosssport website
Stu
Bloody hell!!
Sider is offline   Reply With Quote
Old 08-01-2018, 08:07   #17
plip1953
Phil
plip1953's Avatar
Car: Evo X RS
Originally Posted by Sider View Post
Thatís easy when you have the right equipment
Mine can show all four sensors on the screen at the same time, then, as you move the car, you can see the one(s) not giving an output
Hmm, with respect, I think you'll find that a faulty sensor show ups with the car stationary. If it only happens when moving I suspect it's a different problem eg the whateverit's called thingy in the bearing.
Canít help you with that one. The wheel sensors on eBay ranged from about 10 to 20 quid if I remember correctly, so not worth not doing!
I looked into this and concluded that there were no suitable aftermarket alternatives (at any price).
I think were a hundred or two , I had no problem with the ones I used off eBay, but I went for the dearer ones
Stu
most expensive 1 was nearly £400
Stu
Give Ross a call. Or even check with Mitsi. When I was having to mess around middle of last year with a pair of failed rears I managed to persuade Mitsi that their pricing was incorrect and they altered it. But still worked out to be a ridiculously high price
Phil
stu8 (08-01-2018)
Old 08-01-2018, 09:58   #18
stu8
stu8's Avatar
Car: Evo V - geekmapped.com
http://www.evoxforums.com/forums/sho...ighlight=Codes
Just putting this link here for my own reference
Stu
CPP Motor Developments -
RG Motorsport -
Old 08-01-2018, 12:44   #19
stu8
stu8's Avatar
Well my old code reader didnt read any faults, going to try a mates expensive one, if that brings up nothing, going to ask CPP to put the Kettle on
Stu
RG Motorsport -
Old 08-01-2018, 14:52   #20
Sider
Sider's Avatar
@Plip1953
Yes Phil the reader shows it as faulty then when you move the car you can see the good ones giving a reading and the bad one not, bit like an extra check.
I fitted the ebay specials and they worked, nobodys been back to me to say they have failed. Once I realised how straight forward they are to fit I wasn't worried, in that I thought I could probably fit at least 5 of the cheap ones (that come with a warenty anyway) over a one. Perhaps I was just lucky, who knows?
Old 08-01-2018, 15:17   #21
stu8
stu8's Avatar
evoXforums seems to suggest £40ish sensors do the job too, do you have a link to the ones you use?
Out of interest, the cars with faulty sensors, did they throw up AWC/AYC faults too, as with the fault displayed, I can still toggle though the tarmac gravel snow settings with no problem
Stu
RG Motorsport -
Old 08-01-2018, 15:25   #22
simon ralliart
simon ralliart's Avatar
Car: Evo X Fq300
When mine throws up the 2 lights I cannot toggle through the gravel/snow settings.
its nice to be important, But its more important to be nice......
simon ralliart is offline   Reply With Quote
Old 08-01-2018, 15:26   #23
stu8
stu8's Avatar
hmmm, my ABS light and ASC light are on all the time now, along with the service required message, but I can still toggle through the tarmac gravel snow
Stu
RG Motorsport -
Old 08-01-2018, 15:34   #24
simon ralliart
Car: Evo X Fq300
Mine only comes on when I use a jet washer on it, I turn the car on and off then the codes disappear, so I'm guessing on mine that it's a loose wire/sensor, or 1 of siders dodgy sensors lol
Old 08-01-2018, 15:43   #25
plip1953
Phil
plip1953's Avatar
Car: Evo X RS
@Plip1953
Glad I added the "with respect" bit lol
And I wish I'd known that were cheap ones were actually available
Phil
Old 08-01-2018, 15:50   #26
plip1953
Phil
plip1953's Avatar
Car: Evo X RS
Stu
Pretty sure the tarmac, gravel, snow option became disabled on mine.
I had the same issue with the fault not being picked up even by fairly decent piece of diagnostic kit. But no issues with Snap-on version.
Phil
Old 08-01-2018, 15:51   #27
stu8
stu8's Avatar
I can definitely toggle the modes, will try it again while im actually on the move to be sure tomorrow
Sods law, being my car, it wont be something straight forward
Stu
RG Motorsport -
Old 08-01-2018, 15:54   #28
plip1953
Phil
plip1953's Avatar
Car: Evo X RS
That seems a bit odd as I can't see how even with a jut wash you would get water into the areas where the sensors are located. And the connectors are all either in the bonnet or boot spaces. Unless of course that you jetwash under the bonnet?
Phil
Old 08-01-2018, 16:01   #29
Sider
Sider's Avatar
Stu
To be honest I can't remember what exactly came on now, I've slept since then
Spray the pressure wash at each corner in turn and see if you can sus which one it is
The Following User Says Thank You to Sider For This Useful Post:
simon ralliart (08-01-2018)
Old 08-01-2018, 16:10   #30
simon ralliart
Car: Evo X Fq300
I've no idea, the sensor is behind the wheel so I'm guessing the pressure of the water is making it come on, haven't washed the car in a month and not had the fault come up since.
