Evo 5 steering boss - Mitsubishi Lancer Register Forum
Old 07-10-2016, 12:33   #1
tsg23
User
Evo 5 steering boss
Hi , just re-joined again after purchasing an Evo 5...couldnt resist !
Needs a little TLC and was about to change steering wheel at DTweeks, but no bosses fitted as needs a recess in it ,trying to get a suitable one on order ?
Anybody have any experience on this ?
Help. Seems can't get hold of one. Does anyone know where i can get correct boss ??
tsg23 is offline   Reply With Quote
Old 10-10-2016, 10:07   #2
tsg23
User
bump . help.
Old 10-10-2016, 11:05   #3
OwenVI
Car: Evo 6, stock at the mo
Which wheel are you wanting to fit?
Playskool do a range of bosses. There is a chart on there to identify the correct one too!
http://www.plays-kool.co.uk/acatalog/Boss-K.html
Cheers,
O
OwenVI is offline   Reply With Quote
Old 10-10-2016, 12:41   #4
tsg23
User
Hi, sparco or omp. Boss needs a square recess in it ,which seems none have.
Old 10-10-2016, 12:50   #5
Blacky
Blacky's Avatar
Car: Standard Black TME
This is what you need.
https://www.funkypower.co.uk/catalog...d_product=4663
Blacky is offline   Reply With Quote
Old 10-10-2016, 13:37   #6
tsg23
User
Cheers..sorry for being naive but when wheel is off there is a plastic circular thing with a yellow striker going around it and at the bottom a black plastic square terminal which sticks out for the wires ...does this come off before i put wheel on ?
Old 10-10-2016, 15:02   #7
evo baz
MLR Oldie
evo baz's Avatar
I think you are referring to the clock spring, it provides the electrical connection for the horn / airbag etc.
The boss I used was a "Splash" boss which is a rebranded "Works Bell" boss. It comes with the correct wiring mod to keep the airbag light off and fits with the clock spring in place.
evo baz is offline   Reply With Quote
Old 10-10-2016, 15:36   #8
tsg23
User
thanks Baz........where can I get one ?......Is it compatible with Sparco/OMP st-wheels ?
Old 10-10-2016, 15:40   #9
evo baz
MLR Oldie
evo baz's Avatar
I got mine imported from Japan years ago but the link that Owen posted above is for the UK agent for Works Bell. Yes they are compatible with all 6 bolts steering wheels like Omp, Momo etc.
Old 10-10-2016, 15:44   #10
evo baz
MLR Oldie
evo baz's Avatar
Just checked and my boss was the 817s (s being for "short" as I also fitted a quick release hub)
If your car is a 5GSR then I suspect you'll be after the 817 or 817s but double check first.
Old 11-10-2016, 14:34   #11
tsg23
User
Thanks for your help . Will ask the question.
Does the clock spring have to be removed ? Have been told fitting the wrong boss can have an effect on AYC ?
Sorry for all questions just might attempt it myself !
Old 11-10-2016, 16:18   #12
evo baz
MLR Oldie
evo baz's Avatar
No my clock spring remained in place. Not sure about the boss having an affect on AYC.
I fitted mine myself and I'm not exactly a mechanic.
Old 11-10-2016, 18:34   #13
tsg23
User
Thanks Baz appreciate your help .
Just one more ..lol, did the clock spring have the largeish plastic square bit sticking out at the bottom for the boss to have a recess to fit properly ... just making sure !
Thanks again .
Old 11-10-2016, 23:07   #14
evo baz
MLR Oldie
evo baz's Avatar
I cant honestly remember but there's a few pics that I posted on this thread that may help answer your question.
https://www.lancerregister.com/showth...ht=boss+splash
Old 12-10-2016, 06:48   #15
jmb_silvester
Car: Evo IV with Evo V engine and RS Rear Diff
When im about to change my SW, i've searched on here and found this thread, you might consider the options here: https://www.lancerregister.com/showth...steering+wheel
Old EVO never die, they just get faster...
4G63T leads the way...
jmb_silvester is offline   Reply With Quote
