Cobra goes off randomly - Mitsubishi Lancer Register Forum
Old 13-09-2015, 11:06   #1
kobe_1201
Car: E8 FQ300 with adding lightness bits?
Cud it be the bonnet sensor?? Where is it? Is it on the bonnet or in behind the latch?
kobe_1201 is offline   Reply With Quote
Old 13-09-2015, 11:48   #2
Tony Turbo
Car: Evo VIII MR FQ320+
Mine is on a little bracket by the scuttle panel on the right hand side.
APT & Ross Sport tuned and maintained Evolution VIII MR
My Car build -
< Go on, give it a click
Tony Turbo is offline   Reply With Quote
Old 13-09-2015, 12:22   #3
stu8
stu8's Avatar
Car: Evo V - geekmapped.com
you are looking for a little plunger somewhere where the bonnet meets the rest of the car when its down, also check the boot light is turning off (phone on video in the boot)
Can also be a sign of a failing car battery
Stu
CPP Motor Developments -
RG Motorsport -
Old 13-09-2015, 12:23   #4
kobe_1201
Is it a little sticker thing goes up and down? What do I do to adjust it? I seen previous posts about weather temp affect it so the car sense the bonnet is open?
Old 13-09-2015, 12:24   #5
kobe_1201
I am pretty sure it's the bonnet. Opened it yesterday and played around everything that moves. It went ok for a day and the alarm went off again last night at 3 am. My neighbour must appreciate this so much now. Lol
Old 13-09-2015, 12:28   #6
stu8
stu8's Avatar
if it is the bonnet sensor, you should see 1 wire coming off it, disconnecting and insulating that wire should bypass it
Stu
RG Motorsport -
Old 13-09-2015, 12:46   #7
kobe_1201
Oh? Can I just disconnect it? Great... Thx.
Just to make sure that it's the one on the right hand side, close to the firewall, 10 cm left to the strut tower if u r facing the engine bay right?
Old 13-09-2015, 12:49   #8
stu8
stu8's Avatar
no idea, its aftermarket, so not a standard place, if you want to get an answer, you are going to have to post a pic
Stu
RG Motorsport -
Old 13-09-2015, 13:38   #9
kobe_1201
Aftermarket? I think it came standard on the fq's those cobra alarm??
Old 13-09-2015, 13:42   #10
keithmac
Car: Mk2 Golf Gti 16v
Best thing to do now is go round and apologise to your neighbour(s) and tell them your're fixing it .
My Clifford 650? used to go off all the time from the cabin shock/ proximity sensor. Was a real pita.
GTO TT, Mk2 Golf 16vG60.
keithmac is offline   Reply With Quote
Old 13-09-2015, 14:02   #11
stu8
stu8's Avatar
I meant they are fitted after the car reaches the uk (if standard alarm) I think, so sensor could be in different places
Stu
RG Motorsport -
Old 13-09-2015, 15:37   #12
kobe_1201
hope ive done whatever it needs to be adjusted now... i just slightly bend the plastic piece underneath the little stick thing which goes up and down...
Old 13-09-2015, 16:39   #13
Ads9
Ads9's Avatar
Car: EVO IX FQ320, 2.2 Cosworth, TT S214b, Link G4+ Geekmapped by me (hasn’t gone bang. Yet.)
You should count the flash sequence from the red LED as it'll point out which sensor triggered the alarm- might not be the bonnet!
Ads9 is offline   Reply With Quote
Old 14-09-2015, 07:55   #14
kobe_1201
i think the problem is my driver side door lock... coz i can see the lock open signal on the dash when i closed the door. then i opened it and shut it hard and the light goes away.. im so annoyed now... easy fix?
Old 14-09-2015, 08:50   #15
stu8
stu8's Avatar
interior light? do you just have that off, or does it come on when you open the door, and off when you close the door. The actual plunger for that door are easy to replace, cheap enough, but also they are possible to strip down and clean up the contacts
Stu
RG Motorsport -
