Heaters cold - Mitsubishi Lancer Register Forum
Old 19-07-2015, 13:29   #1
ScotlandEvo
Car: Import 6
Heaters cold
Hi All,
My evo had a broken rad cap and was leaking coolant from it.
I put a new rad cap on (i only jusy got the car)
And the heaters are cold, i never checked them when i bought it.
The heater hoses going into the car are red hot, air con is ice cold.
I took the heater dial out and the ratchet is slipping BUT even when i got it to hot it was still cold.
When i get the dial to cold it blows hard, when on hot it slows down like it should but still cold air.
Any ideas?
ScotlandEvo is offline   Reply With Quote
Old 19-07-2015, 15:01   #2
RyB
RyB's Avatar
Is there enough coolant in the radiator?
RyB is offline   Reply With Quote
Old 19-07-2015, 15:03   #3
stu8
stu8's Avatar
Car: Evo V - geekmapped.com
Also are you sure the heater matrix hasnt been bypassed?
Stu
Old 19-07-2015, 16:03   #4
ScotlandEvo
Car: Import 6
Not sure if its been bypassed? How can i check?
Yep it's full of coolant.
Car temp gauge is perfect aswell.
Old 19-07-2015, 17:21   #5
stu8
stu8's Avatar
usually the 2 pipes, where they go through the bulkhead, are pulled off the bulkhead and linked, to bypass the matrix
From what you have said, it doesnt sound like that has happened, are both the pipes going into the car hot?
Never experienced it but have seen people on here say the adjusters for heater controls can stick, maybe worth a search
Stu
Old 19-07-2015, 19:33   #6
onslow
On my E8 when you turn the temp up or down a motor near the clutch pedal moves to adjust the temp is this moving if you adjust yours?
onslow is offline   Reply With Quote
The Following User Says Thank You to onslow For This Useful Post:
will2 (19-07-2015)
Old 19-07-2015, 20:18   #7
ScotlandEvo
Car: Import 6
Stu
Yea mate both pipes are hot going into the car.
