AYC Electrical issue - Mitsubishi Lancer Register Forum
Old 30-05-2015, 09:20   #1
foxbat
Car: JDM Evo VI GSR
Got an Evo 7 with both AYC & ACD, the car was previously rewired with a complete wiring loom.
AYC pump seems to kick in real soon while in straight line, at minimal throttle rather than full throttle, and it's affecting the car electricity as I see the dash lights dim down for moment when the pump operates! I'm also suspecting that it might be affecting the fuel pump performance. When I disconnect the AYC pump the problem is gone & the car performers better!
Should the AYC pump operate while in straight line at minimal throttle?
I have Evoscan & I can log the AYC ECU, but I'm not sure to look for!
foxbat is offline   Reply With Quote
Old 30-05-2015, 10:00   #2
richyx
for the ayc to kick in on a straight line would be down to a sensor but it runs off so many different sensors
all 4 wheel speed sensors
g sensors
steering angle sensor
ecu
i think abs ecu as well
as you say the wiring has been changed what exactly has it been changed for? and why was it changed
also check the passenger kick well as the ayc loom plugs into the main car loom there behind the kick panel, check for corrosion in the plugs as its a common problem and causes all sorts of issues
richyx is offline   Reply With Quote
Old 30-05-2015, 10:15   #3
foxbat
Car: JDM Evo VI GSR
I'm not sure, the car had some electrical issues & the former owner opted to install a new, entire loom!
Beside the sensors you mentioned, AYC does read TPS angle & brake light switch as well.
I have checked those AYC loom plugs & they look fine.
Since the issue is causing the AYC pump to operates early & in a straight line, the pump is over working & overheating.
Old 30-05-2015, 14:47   #4
Capt.Mike
Car: BMW M4
pump should only run to pressurise system. then cut out on the pressure switch. If the pump is creating excessive load then there would be a higher drain on the electrical system. Correct earthing could be an issue. Can you try someone elses pump? Probably easiest to remove pump and see if it turns easily.
Capt.Mike is offline   Reply With Quote
Old 31-05-2015, 10:04   #5
foxbat
Car: JDM Evo VI GSR
Could it be a faulty pressure sensor? But then I'd have the AYC fault light on.. correct?
Old 31-05-2015, 10:08   #6
richyx
you would yes if it was a pressure switch
but a pump only needs to pressure upto 2.5 bar i think to tirn light off, where they should run 12-15bar
Old 31-05-2015, 12:45   #7
Capt.Mike
Car: BMW M4
I don't know what pressure the light goes out. But as Richy says, if the pressure switch wasn't working then the pump could run and it probably would overheat. There isn't a thermal protection on the pump but there comes a point where something has to give. If you can try another pump that would be best check. Then ayc ecu etc.
Old 25-03-2020, 00:45   #8
adriank
Was this ever resolved? I have the exact same problem!
adriank is offline   Reply With Quote
Old 25-03-2020, 13:16   #9
r3k1355
Have you scanned for fault codes?
Old 25-03-2020, 13:52   #10
grants
grants's Avatar
Scan with what
