No ignition reading! - Mitsubishi Lancer Register Forum
Old 25-10-2014, 10:15   #1
foxbat
Car: JDM Evo VI GSR
As I'm logging an evo 7 ECU, I don't get any ignition timing reading in evoscan while other parameters seem to read fine!
Ignition reads 5 all the time regardless of rpm & load, it doesn't change. The idle timing in the ignition table is 5, I changed it to -10 to see how it would affect idling & there was no effect, the cars idled perfectly fine, ignition reading always stuck at 5!
It seems that the car is unresponsive to ignition timing changes.
I'd appreciate your suggestions what to check for, wiring, ecu...etc
foxbat is offline   Reply With Quote
