Is my evo 8 fq300 running standard map?? - Mitsubishi Lancer Register Forum
Old 08-10-2014, 20:59   #1
chini_01
Car: Evo 8
Hi just abit of help please, Iv got a evo 8 fq300 and running 1.3 bar boost. I got a so called 3 plug mapped ecu from a gsr that was suppose to be running 365bhp plug and play but it is still boosting 1.3 bar? I am going to install a boost controller but shouldnt the boost be higher if its a mapped ecu??
Also would you lot recommend a electronic boost controller or manual cheers
chini_01 is offline   Reply With Quote
Old 08-10-2014, 21:14   #2
chini_01
Car: Evo 8
Deleted post and threads now merged - please only start a thread in one section.
Old 08-10-2014, 21:27   #3
Trebor
Trebor's Avatar
Car: Evo VIII FQ300 (sold) -> Evo IX MR FQ-360 (sold) -> Evo V GSR
1.3 bar is stock boost I think from memory.
Could be several reasons why plugging in a mapped ECU doesn't raise your boost. Depends what other mods the other car had, boost solenoid, boost controller, induction etc etc all could impact in some way.
Personally I wouldn't just swap to a mapped ECU and drive on it, I'd have it done at a tuner's and have the mapping checked as you have no idea if the fuelling is safe.
Trebor is offline   Reply With Quote
Old 08-10-2014, 21:38   #4
Aidy
Aidy's Avatar
Car: Yellow EVO X
1.3 is about standard. As for the map, it depends what was mapped. Sometimes the map is tweaked to handle more boost, but the extra boost itself has to be supplied via a boost controller. You won't see 365BHP on 1.3 bar if the car's other bits are standard. Take it to someone who can read whatever map you have on it and they'll probably be able to tell you if it is standard. I certainly wouldn't trust someone's word and just crank the boost up though.
Aidy is offline   Reply With Quote
The Following User Says Thank You to Aidy For This Useful Post:
will2 (08-10-2014)
Old 08-10-2014, 21:51   #5
lawsy
Car: 7 sprint slag
As aidy points out, most use external boost control and if you don't have a controller fitted it will not be hitting the boost the previous owner had dialled in.
Get it check properly before she blows capain.
lawsy is offline   Reply With Quote
The Following User Says Thank You to lawsy For This Useful Post:
will2 (08-10-2014)
Old 09-10-2014, 07:24   #6
chini_01
Car: Evo 8
Hi the other car was had a 3" through exhaust, induction kit n a 225 fuel pump which mine has but just not the avcr. What is the standard fuel cut??
Old 09-10-2014, 07:29   #7
chini_01
Car: Evo 8
Hi do u recommend any decent tuners near Birmingham and what is the standard fuel cut off? Also the other car had a induction kit, 3" straight through exhaust and a updated fuel pump which mine has but not the avcr would you recommend a manual or electric boost controller
Old 09-10-2014, 07:33   #8
AndyF_RSX
Underground mapper
AndyF_RSX's Avatar
Car: E3 GSR (geek special racer!!) & E9 MR FQ340
Is yours running the exact same induction kit? If not then I would, at the very least, go to somewhere to get the fuelling checked out as a precautionary measure and I definitely wouldn't be turning up the boost without doing any monitoring just because someone has told you that the ECU has been remapped.
Originally Posted by thetyrant View Post
Although Andy sits behind the wheel he is often just a passenger
AndyF_RSX is offline   Reply With Quote
The Following User Says Thank You to AndyF_RSX For This Useful Post:
will2 (09-10-2014)
