how do i read alternate map??? - Mitsubishi Lancer Register Forum
Old 26-09-2014, 20:54   #1
ste53123
Question how do i read alternate map???
hi all!!
just a quick one!! can anyone advise how i read the second map,, i have got a tephra map i think, using ecuflash i can read the map, i know its got a second map because the ics light flashes after its held down,for me to read the second map do i have to have it turned on then use ecuflash or will it read both maps on the first map? hope you understand because i have just confused myself trying to word this!!!
regards ste.....
ste53123 is offline   Reply With Quote
Old 26-09-2014, 20:59   #2
todd-w
todd-w's Avatar
Car: Evo5 Mivec Turbo
which evo and rom ??? its read the lot ,depending on the rom but its usually in the tephra mods section , alternate hi oct fuel map etc
todd-w is offline   Reply With Quote
Old 26-09-2014, 21:11   #3
ste53123
fq300 todd is the rom the internal id??
Old 26-09-2014, 21:17   #4
GUM EVO
GUM EVO's Avatar
Car: 2008 EVO X & 2008 EVO IX
You need XML with tephra mods... then as Todd said alternate fuel map will be located under tephra mod section. If your using a xml without tephra mods the alternate map wont be visible.
2011 CLASS A MLRSS WINNER
GUM EVO is offline   Reply With Quote
Old 26-09-2014, 21:19   #5
ste53123
xml??? i have figured out what is activated and disabled...
Old 26-09-2014, 21:39   #6
GUM EVO
GUM EVO's Avatar
Whats your ecu internal i.d? are you new to ecuflash and have you ever acquired a tephra xml? it's what ecuflash uses to read various code in you ROM image... All xml's are located under openecu/rommetdata/mitsubishi/evo file.
If your just using the standard xml files they wont allow you to view alternate map/tephra mods.
Old 26-09-2014, 21:44   #7
todd-w
todd-w's Avatar
ecuflash uses def or xml files to translate the values from the rom into readable information for us
Old 26-09-2014, 21:45   #8
GUM EVO
GUM EVO's Avatar
If you have the right XML the alternate map is visible where i have marked red on my screenshot below:
The Following User Says Thank You to GUM EVO For This Useful Post:
BobH (28-09-2014)
Old 26-09-2014, 21:59   #9
leecavturbo
leecavturbo's Avatar
Car: Evo8 MG Full Cosworth 2.2L/r stroker,Blouch xtr760,syvecs 9.8sec 30-130
Lol at gum heavily into ecuflash atm
leecavturbo is offline   Reply With Quote
The Following User Says Thank You to leecavturbo For This Useful Post:
GUM EVO (26-09-2014)
Old 26-09-2014, 22:07   #10
GUM EVO
GUM EVO's Avatar
hahahaha.... was well chuffed that I was actually advising someone
leecavturbo (26-09-2014)
Old 28-09-2014, 21:49   #11
BobH
Car: Evo 9 FQ340
We can sort twin maps for you mapped on the Dyno
Give us a call if we can help
Regards
Bob
BobH is offline   Reply With Quote
Old 04-10-2014, 00:46   #12
ste53123
sorry guys not been on for a bit,, gum evo, yes i am new to ecuflash, my rom id is 96260009... i have looked in romdata as u advised nothing says tephra.. just fings like edm,udsm,jdm,udm, but nothing tephra..
Old 04-10-2014, 07:45   #13
GUM EVO
GUM EVO's Avatar
http://www.evolutionm.net/forums/ecu...d-v5-10-a.html
Download version for your rom...
unzip the file and put the xml in that file i mentioned earlier... make sure there are no other 9620009 in that file. If there is simply drag into a file on desktop leaving only the tephra xml in there. after that should be happy days.
Old 04-10-2014, 22:16   #14
ste53123
cheers gum appreciate it pal
The Following User Says Thank You to ste53123 For This Useful Post:
GUM EVO (05-10-2014)
