Boost Problem and engine light on Evo 7 - Mitsubishi Lancer Register Forum
Old 28-08-2014, 18:45   #1
Optimus8
Well guys, I had a thread up about my Evo 7 boost, it's only boosting to 0.7 0.8 max.. Iv looked at the pipes from turbo to actuator to solenoid etc, they all seem fine. What should I eliminate 1st?
The engine light also, had a computer plugged in and what was showing was
P0170 Fuel trim Bank 1
P0400 EGR 'A' Flow
Any ideas or solution on these, thanks 👍
Optimus8 is offline   Reply With Quote
Old 28-08-2014, 19:01   #2
stu8
stu8's Avatar
Car: Evo V - geekmapped.com
how is the boost controlled? standard, boost controller, remapped standard???
for all of the above, could be a knackered actuator. Or else the restrictor in the pipework missing, or in the wrong place. could also be a faulty actuator. 0.8 bar is standard actuator pressure, so i'd guess the actuator is ok, but still needs checking (search on here how to test)
Also, could be a boost leak, is the car standard? had any work done recently?
Stu
Old 28-08-2014, 19:13   #3
Lee5
Moderator
Lee5's Avatar
Car: Range Rover Sport~Porsche 911
If you have just got the car I would say its had some kind of boost control on it before and has been removed to sell the car.
The P0170 is most probably the 02 sensor not working and the egr is normal but this can be turned off in the ECU.
1st 500BHP E5 in the UK Running on Speed Density on Stock H8 Ecu
MLR Sprint Scrutineer
E5/6 Ecu SD Mapping Info Here & HERE
Lee5 is offline   Reply With Quote
Old 28-08-2014, 20:27   #4
Optimus8
Thanks guys.. It's standard boost, as far as I know I don't think there was a controller. The car wasn't driven much, only mods on it is a mani and exhaust. It just boosts up to there and no more, and it's not that quick either boosting up :/?
Old 28-08-2014, 20:30   #5
stu8
stu8's Avatar
I'd agree with Lee, chances are a boost controller has been removed, and put back to standard, incorrectly
Are you attempting to fix this yourself, or taking it to a specialist?
Stu
Old 28-08-2014, 21:05   #6
will2
Regional Organiser
will2's Avatar
As an aside , but relevant ...you say it was standard boost ...but yet why a boost controller fitted in its past life .....or am I bit stella full
Old 28-08-2014, 21:24   #7
Lee5
Moderator
Lee5's Avatar
Stock boost on an E7 should be around 1.2-1.4 bar, when you remove the stock pipework you remove the boost pill as well and this will only give you 0.7 bar
You only remove the pipework to fit a controller :-)
The Following User Says Thank You to Lee5 For This Useful Post:
will2 (28-08-2014)
Old 28-08-2014, 21:30   #8
will2
Regional Organiser
will2's Avatar
Stock near 1.4 .....peak I assume ....
Old 28-08-2014, 21:58   #9
EVO7 RS IAN
The stockboost solenoid is not that great at controlling boost I found.
EVO7 RS IAN is offline   Reply With Quote
Old 29-08-2014, 13:01   #10
Optimus8
I mean the standard boost setup it's only running 0.7 when it should be 1.2 etc, all pipe work is on and seems ok, iv switched pipes on solenoid and it still runs the boost.
Old 29-08-2014, 13:48   #11
stu8
stu8's Avatar
swopping the pipes on the solenoid wont make any difference
if you are going to get your hands dirty, follow the pipe down from the solenoid to the T which then goes off to the actuator and the boost supply nipple. the 2 short pipes that come off the t, you want to have a look in them, or at least give them a squeeze along their length, you are looking for a small solid brass restrictor which is inside the pipe, and if its there, which of those small pipes is it in?
Stu
The Following User Says Thank You to stu8 For This Useful Post:
will2 (29-08-2014)
Old 29-08-2014, 20:41   #12
will2
Regional Organiser
will2's Avatar
As mentioned , check if restrictor is still in line that's Teed off to turbo/j pipe as without it its .7/.8 bar ...had this issue recently with a mate changing turbos ...
Old 01-09-2014, 13:58   #13
Optimus8
Stu
Hi stu,
Iv checked the boost pipes and there is no restrictor in any of them. The pipes are like aftermarket pipes no oem, how will I solve this issue for the pipe to have a restrictor in it to run the right pressure, cheers?
Old 01-09-2014, 14:29   #14
stu8
stu8's Avatar
Hi stu,
Ok, thats a pretty good indicator the car has had a boost controller on it at some point previously
Either get hold of the standard pipework with restrictor (if you do this, make sure the restrictor goes in the right place)
Or fit an aftermarket boost controller
Your choice, depends what you want for the future really
Stu
Old 01-09-2014, 14:38   #15
Optimus8
Stu
Ok, so will I leave the boost as is for now until I get the oem pipe work?
Which is the right place for the restrictor? Just for reference.
I'd more than likely like to keep it standard for another while, cheers?
