TPS Adjustment - Mitsubishi Lancer Register Forum
Old 24-02-2014, 17:21   #1
ad-p
TPS Adjustment
Hi all, iv just adjusted my tps using the sensor check on my avcr, it was reading around 0.5V with the ignition on, I then adjusted it and it hovered in between 0.727 and 0.731V however when the car is running it sits around 0.78V is this correct?
ad-p is offline   Reply With Quote
Old 24-02-2014, 17:35   #2
ad-p
I think I may have moved it slightly actually tightening it up because it now sits at 0.76V with the ignition on, too sensitive
Old 24-02-2014, 17:43   #3
sbn1979
Hi
sbn1979's Avatar
Car: Evo 6 Tommi Mak
If youre struggling Ad pop it over and ill set it up on evoscan
sbn1979 is offline   Reply With Quote
Old 24-02-2014, 18:17   #4
ad-p
Heyup mate I was going to message you actually, my mates coming over to you on Saturday for a map, and I was going to see if you could do me some pops and bangs but I'm struggling to get hold of an Sas pipe
Old 24-02-2014, 18:20   #5
sbn1979
Hi
sbn1979's Avatar
Yes Ad can put some on see how it gets on without the SAS pipe
Old 25-02-2014, 16:56   #6
ad-p
That would be great mate
