My Red TME. Maximum gains from minimum mods. - Mitsubishi Lancer Register Forum
Go Back   Mitsubishi Lancer Register Forum > General Stuff > Picture & Video Gallery
Thread Tools Rating: Thread Rating: 65 votes, 5.00 average. Display Modes
Old 05-09-2013, 08:21   #1
Mr Ralliart
Anthony
Mr Ralliart's Avatar
Car: Evolution 6 TME Ralliart Edition (JDM)
I thought I might post some pics and info about my current car and the slow but sure transformation.., I am always doing something to it I may also regularly post some pics and Video of Track days.
I'm now back living in Japan permanently and have had this Evo (my second) since November 2009. I also now have a Blog about my activities and general car stuff in Japan http://motorsportsinjapan.blogspot.jp/
The 'theme' of this car is "Maximum gains from minimum mods" ; getting the best out of what is there and keeping it as 'streetable' and reliable as possible.
As there were only 212 of these red ones made, I intend to keep it as original as possible and not do or add anything that cannot be simply undone or removed where ever possible. All original parts that have been removed are safely packed away in case they ever go back on the car.
It seems to have been one owner as all the service records were at the same place.
Car came new optioned with Ralliart Intercooler Piping and Suction kit, battery relocation kit. Ralliart / Samco hoses, Ralliart rear Strut Brace, Ralliart stainless exhaust system, Ralliart front LSD, Ralliart Oil and Radiator filler caps, Ralliart Temp Volt Boost gauge set, and Ralliart Mud flaps.
The original owner also fitted a JSpeed ECU, & cat back exhaust.
*The following spec and mod lists I will keep up to date and current on this page*
ENGINE and SUPPORTING MODS (mostly done by myself):
J-Speed ECU with Anti Lag option (mild setting)
J-Speed Turbo Dump (twin pipe) + 3" Front pipe
EXAS Evo tune 80mm stainless cat back and muffler
BLITZ EBC running 1.5 Bar boost
TOMEI Poncam 260 Camshafts
HKS Adjustable Cam Gears
HKS SuperFire Racing plugs (9 heat range)
OKADA Plasma Direct Coils
CUSCO 2ltr competition oil catch tank
HKS Oil cooler kit 210x200mm core + AN10 Aeroquip fittings
TOMEI Blow off valve (Evo VIII MR type)
Walbro 255 fuel pump
MonsterSport Carbon fibre Airbox with 120mm cold air feed from bumper
HPI Air Filter
Custom Earthing kit
Engine Torque Damper
De-Cat pipe
Everything else is standard, I have not had the head or sump off of it. The Turbo is a new, standard RS TD05-16GHRA.
The last tune (before fitting the uprated Coils which made a noticeable difference) produced 376.6hp at the wheels and 355 lb ft at 3967rpm at the wheels (Japan Hi Octane fuel) running 1.5 bar boost (450/430 at the flywheel), with the engine now at 94,000+ klms.
DRIVE TRAIN etc, (all done since I got it):
EXEDY Metal racing clutch (single)
Beatrush short throw Gear shift lever and nolothane shift bushes
OHLINS PCV coilovers + Eibach 12kg/10kg springs
CUSCO adjustable rear Stabiliser Bar,
CUSCO front under braces versions 1 & 2
CUSCO trunk brace.
DIXCEL Heavy Duty slotted brake rotors front and rear.
ENDLESS CC38 /MX-72 brake pads + ENDLESS RF-650 fluid
Ralliart Stainless brake lines
ADVAN Neova AD08 tyres in 235/45 17 on the standard TME wheels.
'Other Stuff':
Ralliart Gear knob
Ralliart Pedal set
OMP WRC Steering wheel
OMP VID 2 Driver's seat
SABELT 3" 4 point harness
PZ Racing 2 stage Shift light
Remote Battery Kill switch
Carbon Fibre cambelt and plug covers, Carbon Fibre Radiator brackets, and a few other bits
Pioneer Stereo and Alpine Speakers
Vanner 30mm lowered seat rails
1.5kg Fire Extinguisher
PIAA Arrow Start White Headlight Bulbs
20mm Wheel Spacers & OMP FIA Tow Hook for Track days
Covered the dashboard with Alcantara 'suede' and other interior mods
Also I replaced the Intercooler, Intercooler hoses and clamps with all brand new old stock Ralliart parts. Originals kept as spares.
Servicing is done by Ralliart in Kawasaki: http://www.streetlife.co.jp/
Tuning is done by Garage G-Force: http://www.gf-eng.co.jp/index.html
Wheel alignments, Drivetrain, and suspension work are done at Anzai Works Gravel & Tarmac Specialists in Kamakura (20 years Works Ralliart WRC Team Mechanic).
This is it about a month after I bought it. The very first thing I did when I got it, was take it to Ralliart and get all fluids front to back changed, new Spark Plugs, and the all important MITSUBISHI sticker on the windscreen.
Ohlins PCV suspension and restored wheel wells.
Interior is in really good condition, I covered the dashboard with Alcantara 'suede', and laminated some panels from a spare dash I have with real Carbon Fibre.
Steering wheel is an OMP 'WRC'.
I have done a fair bit of detailing and it still needs work , but i'm pretty happy with it so far
Airbox is carbon fibre with a big direct cold air intake running from bumper inlet hole. Radiator cooling panel is also Carbon sheet.
Beatrush short throw gearshift. Tall lever and leaning toward driver, very nice bit of gear.
With super low position seat rails.
Hardly used.
Factory option Gauges, Blitz Boost Controller with carbon plate I made.
Mobara Circuit 2010.
Even still today, the grin is never far from my face with this car
Tsukuba Circuit complex short course, Japan 2012.
With Tarzan Yamada after we went for a few (very) hot laps in my car at a track day during summer 2012.
Tsukuba main Track 2013.
My TME progress & track day thread:
Mr Ralliart is offline   Reply With Quote
The Following 32 Users Say Thank You to Mr Ralliart For This Useful Post:
Clivew (20-09-2013), cracker (05-09-2013), darrelt (17-06-2014), DINGER 9 (05-09-2013), dolphin (05-09-2013), EVO VI (01-06-2015), evo5d (06-09-2013), evo6_kelly (19-03-2014), Frog (05-09-2013), Goginawa (05-09-2013), Greeny-o (05-09-2013), GUM EVO (19-12-2013), Gwaldo (26-02-2016), Hank79 (10-02-2018), Iceywater (02-06-2014), [email protected] (17-09-2014), kenzo1 (01-11-2015), markp1983 (20-07-2014), mrfq-360byhks (19-09-2013), NathVI (18-08-2014), Onions (05-09-2013), ray671984 (03-11-2014), Realbadman (19-09-2013), richie9 (18-01-2014), RichW (18-09-2013), river evo 6 (30-08-2016), sanpuu (05-09-2013), shellis (12-12-2016), technoprisoners (04-10-2015), tommymak (03-03-2016), wheelspin (28-04-2016), Zumoku (20-09-2013)
Old 05-09-2013, 08:31   #2
Gwigga
Gwigga's Avatar
Car: Evo X, Cobra Down Pipe back, thats about it :)
NOW THATS CLEAN!!!
More Pics Required
Gwigga is offline   Reply With Quote
Old 05-09-2013, 08:50   #3
Steve666
Jesus that looks almost brand new!! Stunning!
Sent from my Nexus 4 using Tapatalk 4
Steve666 is offline   Reply With Quote
Old 05-09-2013, 09:38   #4
GypsumFantastic
I audibly gasped when I saw those wheel wells! Beautiful car!
GypsumFantastic is offline   Reply With Quote
Old 05-09-2013, 09:55   #5
ptwenty
I just got it out and went for it.
ptwenty is offline   Reply With Quote
The Following User Says Thank You to ptwenty For This Useful Post:
Mr Ralliart (04-06-2014)
Old 05-09-2013, 10:19   #6
Evo Arthur
Car: Evo IX MR
That is a sweet TME, great pics too.
Evo Arthur is offline   Reply With Quote
Old 05-09-2013, 12:00   #7
Gwaldo
Fanboy
Gwaldo's Avatar
Car: Evo IV Mivec Widebody
Brilliant car, subtle yet effect changes. Meeting Tarzan must have been cool!
Gwaldo is offline   Reply With Quote
The Following User Says Thank You to Gwaldo For This Useful Post:
Old 05-09-2013, 13:22   #8
Lucky Nv
Lucky Nv's Avatar
Car: Evo IX MR FQ360
Stunning car, looks very well looked after too and lovely mods.
That beatrush short throw gearshift looks pretty cool, it must have felt very nice and smooth changing throw the gears.
Lucky Nv is offline   Reply With Quote
Old 05-09-2013, 16:18   #9
Mr Ralliart
Anthony
Thanks all for the nice comments
Thanks! Yes, I have met Tarzan a few times. He is a really really nice guy, as many of the Pro Drivers here seem to be. They are often at organised events where they will go with you in your car and give pointers, but always seem quite approachable.
Most track Evo's over here run them. Much longer than the stock lever yet the throw is about 30% shorter.
A few more random shots
The Following User Says Thank You to Mr Ralliart For This Useful Post:
Lucky Nv (05-09-2013)
Old 05-09-2013, 17:02   #10
rockinpete
NICE That's what I call clean
rockinpete is offline   Reply With Quote
Old 05-09-2013, 17:04   #11
KarlosDaJackal
Going faster than b4
KarlosDaJackal's Avatar
Location: Sold the house to live in an 8mile long tunnel....
Car: Audi S3 Quattro :D and fully forged 420/420 M.A.D UK WHITE TME
Great thread... Lovely MAK
Built, Maintained and cared for by M.A.D.....
UK MINT MAK................
The UK TME rare List:
KarlosDaJackal is offline   Reply With Quote
Old 05-09-2013, 17:38   #12
cosevoRS
Amazing, I just love a clean looked after car but also not afraid so give it a good thrashing whilst enjoying a track day, exactly what these were built for.
cosevoRS is offline   Reply With Quote
Old 05-09-2013, 17:50   #13
RabRS
Car: 6 GSR > 6.5 TME > 9 FQ360 > 10 FQ360
Very nice.
Photobucket suck donkeys.
RabRS is offline   Reply With Quote
Old 05-09-2013, 20:47   #14
Lucky Nv
Lucky Nv's Avatar
Do you know if they have anything like that for the evo 9?
All I can find is American company's that do them, no japanese company?
Old 06-09-2013, 06:40   #15
Mr Ralliart
Anthony
Lucky Nv yes they are exactly the same. The only CT that can't use them is the 6 speed.
The reason they only list them as for CP9A is because it will fit inside the standard console and boot (just ), where as with a CT9A you would have to remove / change the boot and modify the console. The CT 5 speed , mounting etc. is all exactly the same as CP.
http://www.laile.co.jp/eng/index.html
The quality is awesome:
Next to the EBay short throw shift lever it replaced:
Lucky Nv (06-09-2013)
