hit a wall! help! - Page 2 - Mitsubishi Lancer Register Forum
Thread Tools Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 11-12-2012, 23:20   #16
yoyojimmy
Car: evolution VI TME
Send a message via ICQ to yoyojimmy
Originally Posted by todd-w View Post
theres no direct link between boost and the ecu it can only measure air flow , make sure you have no boost leaks then set the boost limit to 319 % which is max max do a log check what peak load you hit then reset the boost limit to 10 or 15 above that . say you hit 280 load set it to 290 or 295
Firstly thank you for your suggestion, as you say I had have a try, but get no joy!
Sent from my iPad using Tapatalk
yoyojimmy is offline   Reply With Quote
Old 11-12-2012, 23:29   #17
yoyojimmy
Originally Posted by andy4k View Post
Also compare your boost against the load if you have a boost gauge to determining if you've got a leak
yes I have one buddy,when fuel cut ,it shows about 0.5bar up and down. I dont think there's a leak in somewhere.because when idle the vacuum is so fine . before this time ,I have met fuel cut,after investigating all to see the light because the exhaust leak and the wastegate actuator split.I have fitted a new actuator and a new TOMEI exhaust.
Old 11-12-2012, 23:42   #18
yoyojimmy
Thank u for all the above guys ,here is what I think ,if you no if it is right,please let me no.
I think the problem is the fuel pump relay #2,it swich the fuel pump from low voltage to high when spool,so mine's broken ,it make the fuel pump stay the low voltage as idle ,when boost or wot, the MAF tell ecu need more fuel but the pump couldnt give .
I have check some threads ,some one said if fitted bigger exhaust the AFR will became lean .so I think it is the real reason,what do you think.
before this I have changed a aMAF to see ,no change at all.
Old 12-12-2012, 00:00   #19
Lee5
Moderator
Lee5's Avatar
Car: Range Rover Sport~Porsche 911
Injector resistor pack, if its running lean and you have changed the fuel pumps etc.
Lee
1st 500BHP E5 in the UK Running on Speed Density on Stock H8 Ecu
MLR Sprint Scrutineer
Lee5 is offline   Reply With Quote
Old 12-12-2012, 00:34   #20
yoyojimmy
Lee
Thanks Lee,I think you r right ,I will have a try!but when should I have to change the fuel pump?
check this :https://www.lancerregister.com/showthread.php?t=367012
Old 12-12-2012, 03:00   #21
yoyojimmy
but Im still pullzed,is there anything about Injector resistor pack with fuel cut,look my datalog file ,I found a interesting things, from wot the fire is lacking,from 17 to 12 ,is it normal,I have looked a TME idling datalog file ,it shows 25 as rmp 3500 and speed o,I also think there's problem in fire systerm.what make it that ,somebody nos?
Old 12-12-2012, 03:01   #22
yoyojimmy
Old 12-12-2012, 06:03   #23
andy4k
Originally Posted by yoyojimmy View Post
Do you not log load?
andy4k is offline   Reply With Quote
Old 12-12-2012, 06:33   #24
sbn1979
Hi
sbn1979's Avatar
Car: Evo 6 Tommi Mak
Or tps and wideband?
sbn1979 is offline   Reply With Quote
Old 12-12-2012, 07:08   #25
andy4k
Originally Posted by sbn1979 View Post
or tps and wideband?
TPS is on the left bud but yes where is the load and wideband?
Old 12-12-2012, 18:38   #26
stevov
stevov's Avatar
Car: EVO 5
change the fuel filter on the firewall,right side behind the transmission, bypass it if you don't have a replacement. they can plug and or collapse. i've had both happen and the result is lean fuel under load.also check the fuel pressure regulator is ok.hardwire the fuel pump to eliminate the relay.
stevov is offline   Reply With Quote
Old 13-12-2012, 16:16   #27
yoyojimmy
Old 13-12-2012, 16:19   #28
yoyojimmy
Old 13-12-2012, 16:20   #29
yoyojimmy
I have post 2 new datalog file ,please check and hope can help!
Old 13-12-2012, 16:21   #30
yoyojimmy
