Oil pressure logging - Mitsubishi Lancer Register Forum
Old 14-03-2011, 19:59   #1
EugeneT5
Car: VIII & Volvo C70 T5
Is this possible on the standard ECU, and what sensor/gauge combo would I need?
EugeneT5 is offline   Reply With Quote
Old 15-03-2011, 00:54   #2
grayw
Car: Evo
Yes you can feed an input into the ECU and log it via laptop of OP2 onto SD card. Some people use the input to feed a signal from a MAP sensor or WB into.
Any oil pressure sender with a 0 to 5v output should be compatable.
grayw is offline   Reply With Quote
Old 17-03-2011, 16:02   #3
nousername
Car: Evo 8 FQ300
Would this be the same for Oil Temp?
Evo 8 - For sale!!
nousername is offline   Reply With Quote
Old 19-03-2011, 07:52   #4
wip
Car: 88570008
Not unless you spend a lot of money on the sensor.
You can do it with a generic temp sensor, but you'll need a pull up resistor.
wip is offline   Reply With Quote
Old 19-03-2011, 08:38   #5
R-Spec Performance
Car: Mitsubishi Evolution IX www.rspec.co.uk
I believe these are being used on aftermarket ECU's, although not sure on standard.
http://www.rspec.co.uk/index.php?mai...roducts_id=487
R-Spec Performance is offline   Reply With Quote
Similar Threads
Oil Pressure Problem Twanny Engine / Turbo 3 12-11-2011 15:47
oil pressure help please mk1golf Engine / Turbo 6 12-01-2011 19:54
AMS Dry sump system **NOW AVAILABLE** ECC/AMS.UK Silver Option Traders 13 01-09-2009 09:06
oil temp and pressure thread size YER M4N Technical Questions 1 02-10-2007 14:44
quick oil pressure question CarbonXtreme Technical Questions 2 18-09-2007 20:44
