Tephra 99626009.. looking for add ons - Mitsubishi Lancer Register Forum
Old 16-09-2009, 21:11   #1
scandinavian fl
scandinavian fl's Avatar
Car: 8
Evening all I'm using the above, Can anybody tell me if the xml is editable so that lean spool inable/disable & cold start enrichment can be activated. Ive opened 6& 9 roms respectively and they have it.. short of pulling bits out of xmls & trial error i'm hoping a cyber geek will give me a line I can put in the xml...
Cheers J
Last edited by scandinavian fl; 16-09-2009 at 21:13.. Reason: I hate siht spelling
scandinavian fl is offline   Reply With Quote
Old 16-09-2009, 21:25   #2
grayw
Car: Evo
I have a development XML for that ID, I'll clean out what I've not confirmed and send you a copy with verified tables. I know it has lean spool and cold start enrichment and most of the TPS stuff in.
grayw is offline   Reply With Quote
Old 16-09-2009, 21:39   #3
scandinavian fl
Car: 8
Gray.. I would expect nothing less..
Can't wait IOU Fella
Keep me us up to date
Old 16-09-2009, 21:40   #4
Rasteirinho
Car: Evo VI RS2
Graham, could you please also send me that xml.
Thanks...
'99 Mitsubishi Lancer Evo VI RS2
'85 Toyota Corolla TwinCam (AE86)
Rasteirinho is offline   Reply With Quote
Old 20-09-2009, 22:55   #5
scandinavian fl
Car: 8
Ok got lean spool inable/disable sorted, any pointers on cold star enrichment?
Anybody
J
Old 21-09-2009, 06:00   #6
grayw
Car: Evo
Sorry forgot to dig it out, will do tonight.
Old 21-09-2009, 22:21   #7
Rasteirinho
Car: Evo VI RS2
Don't forget me! pedrogti (at) hotmail.com
Old 22-09-2009, 01:42   #8
ziad
Car: Evo 8MR JDM
can i have it too please, so i can compare it with mine. my email address is ziad at mztec dot org
btw i found the knock load table, WG correction interval and the ram addr for logging boost correction.
is that cold start.... cranking enrichment IPW???? then its 4b9c and 5c7a
ziad is offline   Reply With Quote
