Annoying Aux belt tensioner squeek? - Mitsubishi Lancer Register Forum
Old 18-08-2009, 18:20   #1
Enda
Car: EVO 6 GSR for daily, 00 PY DC2Rx for weekends/track
Rather than pay the mad amount for a new one, simple fix
In my case, the bearing on the end pulley was making the squeek when cold, especially when first starting in the morning and went after a few mins warm up..
So first steps, take of the tensioner complete,
remove the bolt holding the pulley to the tensioner arm.
I left it to set in wd40 while I had the Dinner
Get a vise, and socket and start clamping and slowly tightening(forget what size socket, but make sure its as big as possible as the bearing but small enought to fit into the hole in the pulley)
Bearing removed
New bearing being put back in:
All done :
Started her up and silence Now what to spend the €200 I saved , boost controller I thinks
The bearing is a standard 6203 bearing BTW
Enda is offline   Reply With Quote
Old 18-08-2009, 18:28   #2
grayw
Car: Evo
The OEM tensioner is only £80 new, but still a good saving by just doing the bearing.
grayw is offline   Reply With Quote
Old 18-08-2009, 18:31   #3
Enda
http://camskill.co.uk/products.php?plid=m8b0s2314p3325
thats the cheapest I could find! Misti here wanted even more!
€2 for the bearing and that the only part of the assembly that wears..
Old 18-08-2009, 18:36   #4
grayw
Car: Evo
Ant from Indigo, bought a new one from him a couple of months back for under £90 delivered The castings can crack when you release the tension also.
Old 19-08-2009, 17:48   #5
huwjones
huwjones's Avatar
Car: 309 GTi16 & Integra DC2
Bargain!
It's on my to-do list.
huwjones is offline   Reply With Quote
Old 25-09-2009, 20:58   #6
AnthonyITR
Car: Lancer Evo 6 GSR
Did this last night, was so needed. My bearing was very slack, could tell all wasn't well as the tensioner would jump as the engine revved.
Needed to change water pump pulley as it had cracked, checked the 3rd idler pulley & that had play in it as well, took that off & there is no way to replace that bearing as it's totally enclosed so it'll have to be a new one.
Was well impressed i found this thread as it's saved me a few £££
AnthonyITR is offline   Reply With Quote
Old 26-09-2009, 11:43   #7
Evoboywonder
Car: Evo 7 and Remapped fabia vrs
Great write up, just done it the ,silence is bliss aaaahhh
Evoboywonder is offline   Reply With Quote
Old 27-09-2009, 08:37   #8
stewie
stewie's Avatar
Car: EVO 8 FQ 300. 2.4 4G64 GT35 HTA 640 bhp . Lag is for losers!!!!!
Great thread. Will get cracking and get mine sorted.
I also got quoted stupid prices off everyone.
Breaking gt35hta evo 8
stewie is offline   Reply With Quote
Old 27-09-2009, 11:52   #9
Capt.Mike
Car: BMW M4
Good write up and added bonus of pJictures. just one word of advice (and not trying to teach anyone to suck eggs here) to those doing this job, always make sure that whatever it is you use to press a bearing in or out, is only in contact with the inner or outer race, whichever one is the static race. Pressing the inner race in the above example can be detrimental to the bearing and cause reduced life. Pressing on the outer bearing race in the above example is the correct way to go as there is no stress put across the bearing itself.
There is another way instead of having to hard-press it in. which will much reduce the chance of cracking of the carrier, place the bearing in a cold place (fridge/freezer/etc) and the carrier in a hot oil bath or similar. Once the two are suitably at temperature, drop the bearing into the carrier. You do have to be quick and accurate as the two temp extremes dont stay that way for long.
(I only write this from experience of pressing probably more than 1000 bearings into housings/motors/onto shafts etc. From 20mm to over 200mm ball bearings!)
Hope it helps.
Capt.Mike is offline   Reply With Quote
Old 04-05-2010, 11:58   #10
straightliner
Car: Evo 6 GSR
Great write up very useful, did this on mine today , unfortunately it wasnt this pulley making the noise I am concerned about so back to the drawing board
Took about 40 minutes to do and the old bearing was well its past so perhaps the upper one is on its way as well
straightliner is offline   Reply With Quote
Old 05-05-2010, 23:38   #11
Grant620
Gizzmo Distributor
Grant620's Avatar
Car: 640hp GTX3576R EVO VI Race Car
Which bearing was it?#
6203-2RS, 2Z etc?
Cheers, Grant
01278287346 / 07718384822
Grant620 is offline   Reply With Quote
Old 06-05-2010, 00:05   #12
Unobtainium
Unobtainium's Avatar
Well done.
My latest thread:
Unobtainium is offline   Reply With Quote
The Following User Says Thank You to Unobtainium For This Useful Post:
Macca916 (23-02-2018)
Old 06-05-2010, 07:04   #13
straightliner
Car: Evo 6 GSR
6203-2RS, 2Z etc?
I used 6203-C-2HRS
Bought a couple good quality European ones rather (FAG) than cheap chinese and cost £8 ea
Old 06-05-2010, 07:16   #14
neverneverman
Life after Evo= Elise
neverneverman's Avatar
Car: The money pit has gone ! Lotus Elise now
Did K-evo's yesturday £10 for a good bearing ..
neverneverman is offline   Reply With Quote
Old 07-05-2010, 08:19   #15
straightliner
Car: Evo 6 GSR
There is another idler wheel as well has anyone done that one??
