Evolution 8 MR Road/Track car - Mitsubishi Lancer Register Forum
Old 19-03-2019, 11:11   #1
Blood Speed
Car: evo8mr remap brakes suspension
NEW REDUCED PRICE for limited time.
Now SOLD
Here I have a very reluctant sale, my well loved Mitsubishi Evo 8 MR road/track car. It's a UK car number 66 off the production line.
Itís been in my possession for all but 8 months from new so I can tell you the whole history of the car.
If you are looking for a proper track weapon that will still be a well mannered car on the road then read on.
The Chassis has done 125,000 miles and has a few stone chips and scratches and the rear arche has a little paint chipped, there is no rust at all and the underside has been looked after very well as is washed regularly and sprayed with light oil, especially the Nitron suspension looked after and is like new the material on these is very good quality.
Itís taken us on road trip holidays-euro trips and many track events including over the years, sprint competitions-track days-many Nurburgring trips .
It's currently running about 440hp on 1.4 bar and 480 on high at 1.9 bar making a very smooth wide power band from 2.5 k revs to 7.8 k rev cut.
The car had a complete engine re-build 2 years ago, paperwork to support this.
Here is the full spec sheet.
ENGINE- 2L LONG ROD complete rebuild at 117,000 miles- Built by MG Auto motorsport
Kelford 272 cams.
EXEDY TRIPLEPLATE COVERSION KIT. ID 1050 X 11MM BLUE ADAPTOR TOP
BRIDGEWAY BILLET 4340 I BEAM ROD SET-WISECO1400HD FORGED PISTON KIT
ALC RACE BIG END BEARING SET- ARP L19 HEAD STUD KIT-ARP MAIN STUD KIT
ALC MAIN BEARINGS ETC
HKS 5 LAYER HIGH PERFORMANCE HEAD GASKET-RS INLET VALVE SET-RS EXHAUST VALVE SET- CLEVITE 77 TRI-METAL ROD BEARING SET-CLEVITE THRUST WASHERS
ARP MAIN STUD KIT- FERREA EXHAUST VALVE STEM SEAL AND INTAKE VALVE SEAL
FULLY PORTED AND POLISHED CYLINDER HEAD-ENGINE BALLANCED.
TURBO- HYBRID STANDARD FRAME WITH 23 G WHEEL ONLY 9 MONTHS OLD.
PERRIN INTERCOOLER £600
NEW RADIATOR FITTED 2 YEARS AGO
BATTERY RELOCATED TO BOOT
TRANS
RS REAR DIFF RECENTLY RE BUILT WITH NEW CROWN WHEEL PINION 14 MONTHS AGO
CENTRE DIFF AYC PUMP REBUILT 2 YEARS AGO
CENTRE DIFF REMAPED FOR BETTER TURN IN- ELIMINATES THAT EVO UNDERSTEER.
5 SPEED GEAR BOX WITH GSR RATIOS ĖTHE BEST ALROUND RATIOS IN MY OPINION-RE BUILT AND OVERHAULED 6 MONTHS AGO BY CPP MOTOR DEVELOPMENTS
SUSPENSION CHASSIS
NITRON 1 WAY SUSPENSION WITH CAMBER-CASTER ADJUSTMENT
FULLY POLLYBUSHED
FRONT CAMBER AT 2.5 DEG- REAR CAMBER AT 2 DEG 0 TOW
BRAKES Ė ARE D2 8 PISTON CALIPER BIG BRAKE KIT WITH ALUMINIUM BELLS REAR ARE KSPORT 6 PISTONCALLIPER WITH ALUMINIUM BELLS. CARBOTECH XP10 BRAKE PADS FRONT AND REAR.
FRONT AND REAR HUBS HAVE ALL BEEN REPLACED OVER THE LAST 4 YEARS OR SO WITH GENUINE MITSUBISHI HUBS.
Interior
SPARCO EVO 2 PLUS- COMPETITION FRONT SEATS HARNESS BAR WITH 4 POINT HARNESS
1,75 FIRE EXTINGUISHER AIR BAGS REMOVED AIR CON REMOVED 320 MM OMP STEERING WHEEL FITTED
ALL REMAINING STANDARD FEATURES RETAINED
EXTERIOR
REAR GT CARBON SPOILER CARBON BONNET.
MONGOOSE STAINLESS EXHAUST WITH Dcat PIPE 98DB STATIC. STILL HAVE THE CAT AND IS ALMOST NEW.
WHEELS- ULTRALITES ATAC 2 18 x 8
SECURITY- It has the standard manufacturer alarm. It has a tracker fitted but buyer will need to register it.
I have spent thousands on this car over the years to keep everything mechanical up to running perfectly, and over 12k spent on engine/transmission in the last couple of years.
Tyres have plenty of wear on them as do the brakes pads and discs, Also I have 2 sets of spare wheels, Ultralite wheels and Toyo r 888 semi slick, and.Rota torques in white 18 x 8.5, with Pirelli trofeos semi slick, so you have a choice when buying the car. The spare wheels can be negotiated re the sale if required.
The Private reg plate will also be included in the sale, worth £1,000
Also the engine has just had a bottom end re build at CPP Motor Developments,with new Crank and Rods Bearings etc, all relevant paperwork to support this.
Negative points.
I only have one key fob as the other one got water damage some years back.
There is a small dint and scuff in the rear offside bumper where a taxi driver reversed into it a few years ago the witness didn't get full reg. we heated the plastic and the dint came out but you can still see slightly.
The driver's seat has some wear from sliding in and out on the right bolster with some lining tear, could do with reupholstering but I didn't get round to it.
Remember this is a 14 year old car so cosmetically it will show some wear, but the important stuff has been kept up to the point where the new owner can put miles on the car without the worry of expensive bills, it wants for nothing at the moment.
If you want a very well set up road track car- Bridge to Gantry Nordschleife 7.50s or Donnington park 1.19s with good road manners for those trips etc then this is the ideal car.
I was planning to do some competitions and and more road trips but sadly for personal reasons have to let it go.
Don't waste your time or mine if you are looking for a car with unblemished paintwork,that will probably cost you several thousand pounds later in hidden mechanical faults.
The car is based in Derbyshire.
Reduced price now at £14,550 for limited time as may keep and store away for now.
PM for more info regards viewing of the car, and negotiations and i will PM you with my contact details.
SERIOUS INTEREST ONLY PLEASE.
Car NOW SOLD
"Better to be a racer for a moment in time
than a spectator for all of your life"
Blood Speed is offline   Reply With Quote
The Following 2 Users Say Thank You to Blood Speed For This Useful Post:
peeler (26-03-2019), willox (20-03-2019)
Old 19-03-2019, 19:55   #2
2+barplease
2+barplease's Avatar
Car: Porsche 911 C4S + Evo 5 + SL350
Bargain
Evo 5 as yet unmodded.....
2+barplease is offline   Reply With Quote
The Following User Says Thank You to 2+barplease For This Useful Post:
Blood Speed (19-03-2019)
Old 19-03-2019, 20:59   #3
Greenstar
Very very sad day . Good luck with the sale Alan .
Greenstar is offline   Reply With Quote
The Following User Says Thank You to Greenstar For This Useful Post:
Old 20-03-2019, 06:56   #4
Tom Dick
NR555
Tom Dick's Avatar
Car: Evo VII, forged at NR with a 3076
A great honest advert Alan, wish you all the best for a speedy sale and hope the reasons for the sale are justified, good luck
If your beliefs bring comfort to your heart, Then who am I to try and tear your world apart? I wish you well in your endeavours and your life, And I'll leave you to yours if you leave me to mine, It's not your place to impose religious law on the rest of us like so many have before, and it's equally not my place to say you're wrong I don't have to read your book and you don't have to like this song
Tom Dick is offline   Reply With Quote
Old 20-03-2019, 12:18   #5
Blood Speed
Cheers Tom, Yes would love to keep it, especially the level the car is now mechanically.
Financial reasons mainly.
They really are the most versatile performance car bang for buck out there, and now becoming a real classic.
Mita (20-03-2019), Tom Dick (20-03-2019)
Old 20-03-2019, 15:03   #6
JamR
JamR's Avatar
Car: White 5,Silver 6, Eissen Gray 7,White 7RS blue 7, 8RS gone but not forgotten.Now8MR,silver6+Godzilla
Sorry to see you sell it mate
All the best for the future
RG MOTORSPORT BUILT AND MAINTAINED
QUALITY PARTS BY:- ROSS-SPORT,[email protected] NEVERNEVERMAN, EARS & BRIGHTON MITSUBISHI
JamR is offline   Reply With Quote
The Following User Says Thank You to JamR For This Useful Post:
Blood Speed (20-03-2019)
Old 20-03-2019, 20:46   #7
kins
Regional Organiser
kins's Avatar
Car: Evo VI RS
Sorry to see you selling her Alan - GLWTS
The Following User Says Thank You to kins For This Useful Post:
Old 21-03-2019, 19:15   #8
Joelraw
Joelraw's Avatar
Hi mate have you got a contact number please for my friend thanks
Sent from my SM-G950F using Tapatalk
Joelraw is offline   Reply With Quote
Old 22-03-2019, 00:56   #9
Blood Speed
You have PM.
Old 24-03-2019, 16:25   #10
DAMN!Nice
Hi Alan.
Do you still have the Original Evo 8 Parts?
Cheers Marc
DAMN!Nice is offline   Reply With Quote
Old 25-03-2019, 19:29   #11
Blood Speed
Originally Posted by DAMN!Nice View Post
Hi Alan.
Cheers Marc
No, apart from a few bis of plastic, oh and the steering wheel...air bag and air con unit
Old 28-04-2019, 23:31   #12
Blood Speed
Reduced price for limited time.
Old 30-04-2019, 22:08   #13
Blood Speed
Sensible offers considered, also part ex considered but got to be fair cash my way difference.
Old 19-05-2019, 18:43   #14
Blood Speed
Still for sale ! Really can't believe my car has had no interest what so ever, seeing some of the evos on here for sale at silly prices.
One i noticed recently and 19 years old sold for around 12k i think "good honest add " saying needed some chassis rot sorting" Mine has done some mileage but has no rot what so ever and one owner for 14 years, Surly that has to stand for something. Hey but maybe there is a buyer just round the corner.
All i can say is come and view the car and see the value, Its as smooth as! with no noises rattles or vibrations. Rant over
The Following User Says Thank You to Blood Speed For This Useful Post:
Mita (19-05-2019)
Old 19-05-2019, 19:20   #15
Mita
If I was looking I would buy this in a heart beat. What more could you want? A sorted Evo that you can enjoy
Blood Speed (19-05-2019)
Similar Threads
Mitsubishi Lancer Evolution Evo VII Fast Road/Track Car, Big Spec! benntrevv Private Sales - Cars 2 11-07-2016 23:13
Official Mitsubishi Evo 9 FQ-360 MR information & images Darin Lancer Chat 147 28-04-2010 21:23
For Sale - Prodrive Development RB320 - BJ56 OJS ScottyRB320 Non-Evo Cars for Sale 10 08-06-2009 12:49
2004 (04) Gunmetal Grey EVO VIII MR FQ-320 (UK car) MR F Quick Private Sales - Cars 18 29-10-2006 09:25
