04 EVO8 MR-FQ340 sticky 6th - Mitsubishi Lancer Register Forum
Old 10-05-2020, 15:51   #1
Hampshire_Nick
Hi All,
As the title suggests, I've a small Gearbox issue.
I am a returning member from. . er. . years back. I have had to re-join with a new name, but it is still me I have owned the same EVO from new in 2004, and it is simply a car that I can't sell, as nearly 16 years and 99,000 miles together I still smile when seeing off M3s who check the reg and think they have a chance
A number of months back I missed 3rd under moderate acceleration and crunched the change. Since then the box has to be coaxed into 6th, and once "In" needs to be coaxed back into lower gears. I live with it, but it is something I would love fixed.
Does anyone have any recomendation for someone who can give me a reliable (EVO quality) transmission overhaul somewhere locally to Basingstoke?
Any help and advice is welcomed, and I appoilogise if this question has been asked before.
Keep EVOiing all.
Nick
July 2004: Gunmetal EVO8 MR-FQ340: Totally unmodified and completely standard.
Hampshire_Nick is offline   Reply With Quote
Old 10-05-2020, 16:24   #2
Fraggle13
If you can get the gearbox out, my advice would be to send it to Clive, his on here. Rebuild my 5 speed. Now perfect!
Fraggle13 is offline   Reply With Quote
Old 11-05-2020, 10:54   #3
Hampshire_Nick
Thanks Fraggle . . . Now, I guess I'll have to track down Clive.
Nick
Old 11-05-2020, 11:09   #4
Mita
Clive - mailto:[email protected]
Old 11-05-2020, 11:31   #5
Hampshire_Nick
Thank Mita,
I guess if Clive monitors here he will be expecting a messge.
Nick
The Following User Says Thank You to Hampshire_Nick For This Useful Post:
Mita (11-05-2020)
Old 11-05-2020, 16:39   #6
wizzzbang
Clive is a top guy and great Engineer. When I last talked to him, he said he did not rebuild 6 speeds. From what I have read on here most people change to a 5 speed. If that is the route you end up going then you should talk to Clive about an RS 5 speed with a 4.11 final drive. It transforms the car to another level.
wizzzbang is offline   Reply With Quote
Old 23-05-2020, 19:17   #7
Hampshire_Nick
Thumbs up Thank you for all your help guys.
Thank you to all above who have helped me with my problem with 6th.
I have made contact with Clive and as soon as I can take the vehicle off the road for a while he knows there is a job lined up for him.
Today's EVo task (whislt otherwise locked down) was swapping out the front wheel bearing flanges. Easier that I expected, but those bolts hadn't been turned for 16 years, so were wonderfully tight. . . a 32mm 1/2" socket, a borrowed breaker bar and another borrowed length of scafolding pole eventually got things moving. . . What could be easier??
Thabnks again all.
Nick
Old 23-05-2020, 19:21   #8
Hampshire_Nick
To wizzzbang: Thank you for the pointers, but even after 16 years (of sole ownership) the car is absolutely standard as the day it came new to me from Mitsubishi. I haven't uprated anything which should make it a sought after car when I come to sell-it one day as nothing has been stressed more than the design spec. We'll find out if that is true the day I come to move it on.
Nick
