Evo 6 tme lhd – work log - Page 3 - Mitsubishi Lancer Register Forum
Go Back   Mitsubishi Lancer Register Forum > General Stuff > Picture & Video Gallery
Old 15-04-2017, 15:17   #31
madmatt
madmatt's Avatar
Originally Posted by ant1 View Post
Was It hard to remove the tints?
Was very hard. Took me about 5 hours with the help of my girlfriend.
The Following User Says Thank You to madmatt For This Useful Post:
ant1 (15-04-2017)
Old 15-04-2017, 17:15   #32
M3 ROB
M3 ROB's Avatar
Car: Evo 6 TME,
I've done my fair share Ant, if you warm it first with a hair dryer it comes off fairly quickly, then warm soapy water and a tungsten blade to get the glue off
M3 ROB is offline   Reply With Quote
The Following User Says Thank You to M3 ROB For This Useful Post:
ant1 (15-04-2017)
Old 15-04-2017, 17:24   #33
ant1
ant1's Avatar
Car: Evo TME RS
Heat gun to much for the job?
ant1 is offline   Reply With Quote
Old 15-04-2017, 17:33   #34
M3 ROB
M3 ROB's Avatar
Car: Evo 6 TME,
yeah it just shrivels up
Old 18-04-2017, 16:06   #35
madmatt
madmatt's Avatar
Upon removal of my front bumper, not only did I find my oil cooler has a little dent in it (god knows how it happened), but I am also missing a duct I believe.
Is there supposed to be a duct in front and rear of that oil cooler or?
Old 14-05-2017, 17:30   #36
madmatt
madmatt's Avatar
Took the Evo out on mountain roads, pleasure to drive.
Although I still have to change few things:
- steering rod and rod ends
- front top mounts
- front and rear wheel bearings
- new tyres and geometry
Then it should be perfect. But I still cannot remove the driveshaft from the hub to change the rear left bearing, I will have to take the whole assembly off and use a hydraulic press. PITA
Old 08-06-2017, 13:19   #37
madmatt
madmatt's Avatar
So I've changed the steering tie rod and rod ends, the play in the steering has been reduced, although what's left of it might be normal, or maybe I'm expecting too much (never driven other TMEs before). The nasty knock on full lock has been reduced as well. Got the parts from viamoto, they are not exactly like oem as you would expect, the biggest difference is that you need a 30mm crow spanner, rather than a 32mm for the oem rod.
My PAS pump is making noises as well, so will have to change it! Are they the same on Evo 6s and TMEs?
I need to check if the diff bolts are broken or not, because I still hear a knock on full lock under my feet (LHD car). Heard the TME doesn't suffer from this failure since the design is different, but I guess I have to open the case anyway.
Old 12-06-2017, 14:28   #38
Robin651
Now this is a cherry looking ride. lhd to boot! Amazing!
great job on keeping her up to spec.
Robin651 is offline   Reply With Quote
The Following User Says Thank You to Robin651 For This Useful Post:
madmatt (21-06-2017)
Old 24-07-2017, 17:33   #39
madmatt
madmatt's Avatar
Cleaned the car, and especially the wheels. Went for a drive, still few knocks here and there, but I love the acceleration and handling. A rocket!
The Following 3 Users Say Thank You to madmatt For This Useful Post:
joe81 (25-07-2017), M3 ROB (24-07-2017), squeakyclean32 (03-08-2017)
Old 24-07-2017, 19:59   #40
M3 ROB
M3 ROB's Avatar
Car: Evo 6 TME,
Looking great matt
madmatt (24-07-2017)
Old 24-07-2017, 23:55   #41
Gg3001
Gg3001's Avatar
Looks lovely
Gg3001 is offline   Reply With Quote
The Following User Says Thank You to Gg3001 For This Useful Post:
madmatt (25-07-2017)
Old 25-07-2017, 18:09   #42
madmatt
madmatt's Avatar
Thanks guys! What spacers can I use to just make the wheel pop out without rubbing the arches? Just want them to fill the arches more. They are std TME wheels and the car has std suspension.
Old 03-08-2017, 19:19   #43
cosevoRS
be interested to see what the difference is, if you try spacers, I'm considering going back to standard wheels very soon, please try to get another shot from the same angle as above so we can see the difference.
cosevoRS is offline   Reply With Quote
Old 04-08-2017, 07:22   #44
madmatt
madmatt's Avatar
Yea, that is if I can get an answer on what is the maximum spacer width I can use without rubbing the arches
Old 16-08-2017, 19:56   #45
LeeL
User
Lovely car mate forgot they produced them in red hope you are enjoying
LeeL is offline   Reply With Quote
The Following User Says Thank You to LeeL For This Useful Post:
madmatt (25-08-2017)
