Evo 8 600bhp for sale, massive spec - Mitsubishi Lancer Register Forum
Old 13-06-2020, 20:16   #1
Flans
Junior User
Car: Evo 8
For sale is my stunning Evo 8 FQ300
First some history of the car. I have had this car now for just over 6 years. It was running 380bhp when I bought it from a guy in Bradford. I drove this for over a year on this spec and never missed a beat. I decided in 2015 I would do a massive spec engine build, over a year later it was completed, running at 551 bhp.
After this up to present sadly I never got to drive it that much with work commitments and starting a family. I decided that I wanted to do an overhaul on the car again as it wasn’t driven much and I wanted to sell her so I put a few extras on her and she is now putting out just over [email protected] 1.7 bar
This engine is capable of over 700bhp easily, it has top of the range parts put in as you will see below, I have spent over 25K on this engine build and she has been looked after well. Inside is immaculate and exterior is in great condition also, just with a few age related marks. This car has been my pride and joy for the last 6 years and I will be sorry to see it go, but someone else should get the enjoyment from her. This thing is seriously fast and very loud. One of the nicest Evo’s about in my opinion.
Spec is
Engine
Link G4 ECU
Link 4 bar map sensor
2.3 stroker
Bore cylinders to 1mm over size
Engine block only 10k miles
Wiseco HD 1400 pistons and rings
Oliver extreme ibeam rods
New 4g64 crank 100mm stroke
ACL Big/small end, thrust bearings
Balance shaft delete kit
ARP L19 head stud kit
ARP bottom end stud kit
ARP exhaust manifold stud kit
New oil pump
New waterpump
New mishimoto oil cooler
Cosworth gasket
New air fuel ratio sensor
New esc power division stem seals
Head port and polished
Head just newly refurbed, pressure tested and resurfacing
Head Gasket siruda drag
Ferrea 1mm over size valves
Ferrea valve srings and guides
Kelford 272 cams
HKS adjustable cam gears
HKS fine tune timing belt
Zaklee clear cam cover
Cusco oil catch can
HKS 4” drag intercooler
JM Fabrications coolant overflow can
JM Fabrications battery mounting kit
AMS F1 cast air intake manifold
Tomei spark plug cover
Torque solutions 3 piece billet engine mounts
NKE polished steel fuse box and relay covers
BBK Powerplus 75mm throttle body
Spec R power steering Reservoir
3 port boast solenoid valve
Green vacuum hoses and pipes
Mishimoto performance aluminium radiator
Mishimoto slim electric fan
Garrett GT3582R turbo and manifold with Zirotec Coating, inc wastegate
Tial BOV
K&N Ari filter
Dress up bolts and washers
STM Polished radiator brackets
AEM Oil pressure gauge
AEM Air fuel ratio gauge
AEM Boost pressure gauge
No doubt I have missed things here.
FUELING/ ENGINE MANAGEMENT
Injector Dynamics 1300cc injectors
Fuel Lab 525 series pressure regulator
AMS Fuel Rail
NEW Audi R8 coils on plug conversion
Braided fuel lines with an fittings
Swirl pot in boot
External Bosch 044 twin fuel pumps
SUSPENSION/HANDLING
Cusco front member brace
Carbing evo poluished 3 point strut brace
Tein adjustable coil overs
Full refurbishment on ayc pump with 6 months warranty still left
Brembo 4 pots
GEARBOX/TRANSMISSION
New Excedy twin plate clutch
New Excedy release bearing
Standard 6 speed box
EXTERIOR
Vortex generator
Tomei expreme ti exhaust system ( this thing is LOUD )
Carbon front and rear splitter
Ralliart mud flaps
INTERIOR
Carbon gauge front plate
Trim is carbon dipped
CD Player
Hands free
HKS Turbo timer
Personalised reg F5 EVO
As I said before there has probably been plenty that I have missed but as you can see with the spec, this car has wanted for nothing and no expense has been spared. I have tons of receipts for all the parts that have went on this car.
Most recent work has been done by Lipton auto repairs in northern Ireland here. Lee is fantastic at his job and I could not recommend him enough for the work he has done, the recent remap has been done by Richard Bradley motorsport, again an excellent man in his field.
I am based in county Tyrone, Northern Ireland
Price is £24,950
I can whatapp on more photos as only lets me upload 6 attachments
Either contact me on 07759496664 or [email protected]
Thanks for looking
Flans is offline   Reply With Quote
The Following 2 Users Say Thank You to Flans For This Useful Post:
bjr24uk (24-06-2020), dreMR (13-06-2020)
