evo 6 tme - Mitsubishi Lancer Register Forum
Old 11-06-2020, 12:20   #1
kevincartmell
evo 6 tme
Tommi makinen evo big spec 550+bhp!! Garage find dry stored!! Unfinished project 95% finished with parts to complete! Jap import. Looking for around 15k Ono Spec as follows
Engine
Stainless exhaust system manifold down pipe and screamer pipe
Garrett Gt3582r turbo with turbosmart 38mm external wastegate
Rc 1000cc injectors
Kelford 272 cam shafts
Hks adjustable cam pulleys
3mm lash adjusters
Uprated valves guides valve springs titanium valve spring retainers
ARP head studs
Hks head gasket
Balance shaft machined down lightened/balanced
Not deleted no strain on the oil pump this way!
Manley con rods
Wiesco pistons and rings
Air con deleted
Battery relocated
Walbro 255 fuel pump
3 port boost solenoid
Stainless de cat exhaust
Oil breather tank
Alloy radiator
Some silicon hoses
Hdi gt2 uprated intercooler
Hard intercooler pipes
Tial v band dump valve
102mm intake pipe
Large k&n filter behind headlight
Exedy twin plate clutch
Coil on plug conversion
Yaris coilpacks
Autronic ecu
Aem 320lph fuel pump (not fitted)
Brakes
Brembo calipers
Braided brake flexi lines
Uprated discs/pads
Suspension
Ralliart adjustable shocks
Lowering springs
Some poly bushes
Front/rear strut braces
Interior
Std tommi makinen plus the following additions
CD player
Boost gauge
Oil pressure gauge
Ralliart gearknob
Fans on illuminated toggle switch
Updated speakers
Custom starlight roof lining
Custom led parcel shelf
(Disconnected)
Exterior
Carbon bonnet vent
Black oil cooler vent
Black lightweight alloy adjustable spoiler blade
Fog light wired into reverse light
Ralliart sunstrip
Black pvc mud flaps
Probably bits I’ve missed?
The car is a really solid and clean example underneath 100% solid. Around 2000 miles on fresh engine rebuild and 83000 on the shell. Been off the road for a number of years but dry stored and maintained inside garage. Has new abs sensors up front new track rod ends fresh oil/coolant plugs fuel filter etc plus a few other bits refreshed. Comes with new rear abs sensors front drop links hks cam belt and few more std parts/spares
Bad points
Needs rear abs sensors fitted and abs rings cleaned up from sitting unused. Import so mixture of miles and kilometres showing on history. Speedometer was replaced with a 2nd hand unit by previous owner the original broke and mileage not corrected shows around 60+k? Actually around 83k miles. (Only 2000’ish on engine since rebuild)
GSR wheels fitted but clean ones
Bumper doesn’t quite sit right due to pipes for bigger intercooler but not that obvious I don’t want to cut the bumper as it’s genuine. Some minor age related marks the odd stonechip etc. Map for 550 on s205b ewg but gt35 now fitted. Sent spoiler blade away to be painted before lockdown not been able to get it back yet due to pandemic hoping to have it ASAP will post on if not here at time of sale! Thanks for reading genuine interest only
SOLD
kevincartmell is offline   Reply With Quote
Old 11-06-2020, 13:06   #3
jdm4life
I am sure Stevie Wonder would agree.
**** your signature
jdm4life is offline   Reply With Quote
Old 11-06-2020, 13:39   #4
grants
grants's Avatar
And install, or not, 3 different fuel pumps
Old 11-06-2020, 16:07   #5
tikky786
Car: evo 6
MOT history shows far too many discrepancies
tikky786 is offline   Reply With Quote
Old 12-06-2020, 12:19   #6
big S
Wonna see that Custom starlight roof lining.
Evo 7 fq Mr 260!
big S is offline   Reply With Quote
The Following User Says Thank You to big S For This Useful Post:
jdm4life (12-06-2020)
Old 12-06-2020, 12:46   #7
tikky786
Car: evo 6
Cars a mess!!
Good for breaking. Underneath looks like someone painted white with a roller. No invoices for engine to confirm what parts have been used. Mileage discrepancies. Wrong clocks. Wrong wheels etc
Old 12-06-2020, 16:14   #8
Jaaymm
Junior User
Has anyone been to see this in person ?
Jaaymm is offline   Reply With Quote
Old 12-06-2020, 17:08   #9
Mita
Looking at the pictures I don’t need to
Old 12-06-2020, 18:07   #10
Jaaymm
Junior User
Aaah just seen the under carriage ... yikes
The Following User Says Thank You to Jaaymm For This Useful Post:
Mita (12-06-2020)
Old 12-06-2020, 18:17   #11
Mita
And thatís his attempt to make it look good
Old 12-06-2020, 18:19   #12
Mita
Dry stored , barn find and 100% solid is everything I need to know
As soon as someone states that, it’s game over
Alex T (12-06-2020)
Old 13-06-2020, 11:34   #13
jdm4life
As soon as someone states that, itís game over
New house, new baby, new company car forces sale
Pulls like a train
1 previous owner (female Doctor)
Pops and bangs bro
**** your signature
The Following 2 Users Say Thank You to jdm4life For This Useful Post:
bjr24uk (24-06-2020), Mita (13-06-2020)
Old 13-06-2020, 12:31   #14
jameswrx
jameswrx's Avatar
Car: Evo 6 & Impreza
Does the seller have previous here or something?
Tough crowd these days.
Granted it looks a bit rough underneath but I’d wager 90% of evos out there look like it these days. Last one I had was 10 years ago and they were rust buckets then.
AYC noise when cornering? See my guide to killing the donkey
https://www.lancerregister.com/showthread.php?t=196813
jameswrx is offline   Reply With Quote
The Following 2 Users Say Thank You to jameswrx For This Useful Post:
j dog (13-06-2020), mspbarry (13-06-2020)
Old 13-06-2020, 14:57   #15
kevincartmell
sold can be removed now not been on here previous but certainly wont be returning many thanks
The Following User Says Thank You to kevincartmell For This Useful Post:
jdm4life (13-06-2020)
